Home > Off Topic > 24 volt to 12 volt
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
24 volt to 12 volt
I have a 24 volt army boiling vessel that I want it use in my Defender. It has quite a current draw but I wondered if it were possible to run it from 12 volts using some form of converter? Any ideas?
Post #329301 8th May 2014 2:58pm
Eduardo
Yes, It is possible.
In fact there are several 12V to 24V converters. All will depend of how much current draw the equiment to buy the rigth converter.
Here one example
http://www.ebay.com/itm/DC-Converter-240W-...1329329038
Cheers! Eduardo
Post #329305 8th May 2014 3:07pm
borderterrier
Thanks mate, it's a hefty big of kit so I reckon a heavy duty converter will be needed
Post #329307 8th May 2014 3:15pm
Cupboard
If it's just a resistive heating element then it will probably work at 12V, just slowly.
Post #329409 8th May 2014 8:10pm
borderterrier
Good point Very Happy
Post #329410 8th May 2014 8:17pm
I looked at fitting a BV into my 110. It's a helluva current draw. I dismantled it and looked at finding another element to fit inside, a 12v one, but didn't go into too much searching and eventually binned it.
I reckon if you got a couple of those travel kettles, you could canniblise the elements and fit them into the BV casing though.
Post #329916 10th May 2014 4:05pm
borderterrier
Or I could part ex the 110 for this!
Post #329924 10th May 2014 4:40pm
