![]() | Home > Off Topic > 24 volt to 12 volt |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Yes, It is possible.
In fact there are several 12V to 24V converters. All will depend of how much current draw the equiment to buy the rigth converter. Here one example http://www.ebay.com/itm/DC-Converter-240W-...1329329038 Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Thanks mate, it's a hefty big of kit so I reckon a heavy duty converter will be needed
If it's just a resistive heating element then it will probably work at 12V, just slowly.
Good point
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
I looked at fitting a BV into my 110. It's a helluva current draw. I dismantled it and looked at finding another element to fit inside, a 12v one, but didn't go into too much searching and eventually binned it.
I reckon if you got a couple of those travel kettles, you could canniblise the elements and fit them into the BV casing though. |
Or I could part ex the 110 for this!
