Home > Technical > Dif Lock light
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Dif Lock light
Hi all,
New on here and got my first Defender 90.
The diff lock doesn't come on when I put it in Low or High box, shouldn't it come on in Low and how much does it cost to fix?
Thanks
Tim
Post #328743 6th May 2014 5:56pm
The diff lock light should come on in either high or low box - which model Defender do you have ?
Edit: Just checked your previous posts and can see you were looking for a TD5.
Do you mean you are putting the transfer box lever in to the 'low' position and no light comes on or are you sliding the lever across into 'Diff lock' and no light is coming on ?
Post #328744 6th May 2014 6:02pm
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Mine doesn't by purely knocking the lever over.
If I drive forward a few metres, it then comes on. Try that?
Post #328745 6th May 2014 6:05pm
timtom1
Hi its a 2001 TD5, I've already slid it across so its when I put it into, high or low, I have driven forward and backwards a few meters
Post #328746 6th May 2014 6:10pm
Forgive me if I'm teaching you to suck eggs but I think you maybe confusing the use of the diff lock.
On the fuse box cover there should be a diagram for difflock / high / low use.
Just moving the lever into low will NOT turn on any warning lights, you'll know its in low as the gearing is much much lower
The warning light on the dash should illuminate when you move the lever sideways (not forward or backward) into 'Diff lock', this can be used in high or low (Google or read your handbook) and will lock the front and rear diffs together
Post #328747 6th May 2014 6:14pm
timtom1
ahh ok, thanks, no I appreciate any advice I am a complete novice
Post #328748 6th May 2014 6:16pm
Thumbs Up
This forum is a great source of knowledge, use the SEARCH facility and you'll learn loads - enjoy Cool
Post #328749 6th May 2014 6:19pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
The light often won't come on straight away, even when you slide it across to put it in Diff-Lock. You will need to travel a short distance so it engages the lock.
Likewise when you unlock the diff, you should do it while still on loose ground or if not you may need to reverse a short distance to "unwind" the transmission and allow the diff to disengage.
Hope that makes sense..!
Simon
Post #328754 6th May 2014 6:39pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
depending on the previous use it might be stuck - the previous owner of mine never used diff lock and as a result it refuses to go into lock unless you crawl underneath and give the lever a smack from below Mad
Post #328767 6th May 2014 6:58pm
barbel jim
It could also have an early 1.2 disco transfer box, which probably dose not have the electrics, meaning they will never come on Thumbs Up
Post #328776 6th May 2014 7:44pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Mine only comes on after it's immersed in water! Faulty wiring methinks.
Oh, did you know that William Shakespeare invented the word "methinks"? There's a pub quiz winner for ya! It wasn't me!
Post #328784 6th May 2014 8:02pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
I too have a 2001 TD5 my diff lock light wouldn't come on either,I eventually worked out the linkage from the lever to the box was seized through lack of use, half an hour stripping it down loosening it off re lubricating it and putting it back together solved the problem.
I understand it's a common problem with the linkage exposed to all the road crap, salt moisture mud and grit.
Another solution could be to check the switch located on the transfer box, mine needed a slight adjustment out, to prevent it from stopping the diff lock engaging.
Once sorted make a point of using it a couple of times a month just to keep it freed up.
Hope this helps
If I remember there's a good example on YouTube.
DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #328787 6th May 2014 8:15pm
timtom1
thanks for your help guys!
Post #328814 6th May 2014 9:22pm
