Home > Puma (Tdci) > Engine bay work lamp live feed
keith
2.2 engine . Where can I get a live feed from to power work lamp using crocodile clips ?
Post #325412 22nd Apr 2014 7:54pm
munch90
I think if I wanted to regularly use work light under bonnet I would run fused feed to socket under bonnet ,
also if you do run a fused heavy wire to under bonnet it makes it easier to wire added gadgets to in the future !!
Post #325436 22nd Apr 2014 8:29pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Thats what I did.
I ran two wires - 16mm2 earth and live direct from battery to a 6 blade-fuse box mounted in the engine bay. from here I tap power for my spots, vhf radio etc....
Post #325942 25th Apr 2014 7:35am
Starter motor ?
Post #325943 25th Apr 2014 7:47am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Yeah starter motor and earth onto an engine bolt, i used a PAS pump bolt. William
Post #325961 25th Apr 2014 10:09am
keith
Thank you . Starter it is . Great help Thumbs Up
Post #326061 25th Apr 2014 8:56pm
munch90
personally I would go back to battery as its easier to put a fuse close to end to protect wire , fuse can be inside battery box easy to change and out of damp etc
as normall any wire should be run though protective sleeving
fuse down by starter motor is not so easy to get at
Post #326100 25th Apr 2014 10:11pm
