![]() | Home > Puma (Tdci) > Engine bay work lamp live feed |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2278 ![]() ![]() |
2.2 engine . Where can I get a live feed from to power work lamp using crocodile clips ?
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
Thats what I did.
I ran two wires - 16mm2 earth and live direct from battery to a 6 blade-fuse box mounted in the engine bay. from here I tap power for my spots, vhf radio etc.... |
Starter motor ?
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Yeah starter motor and earth onto an engine bolt, i used a PAS pump bolt. William
Thank you . Starter it is . Great help
personally I would go back to battery as its easier to put a fuse close to end to protect wire , fuse can be inside battery box easy to change and out of damp etc
as normall any wire should be run though protective sleeving fuse down by starter motor is not so easy to get at |
