![]() | Home > Puma (Tdci) > Now it's the chuffing turbo |
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 ![]() ![]() ![]() |
My 2007 Puma 90 has been diagnosed, for the second time, with a failed turbo, it had the same fault about 5000 miles ago, and went again on Saturday. It starts off as a high pitched whine, and then as the turbo deteriorates turns to a banshee like wail. LR have been very good about it, I have a FL2 on my drive and that will be replaced by a FFRR tomorrow as the FL2 won't tow the skin off a rice pudding.
AndrewS has had the same turbo problem, but only once, so I am concerned that I treat my truck harder than he does ![]() ![]() ![]() The trouble is I am starting to lose confidence in my 90, at this rate I feel a D3 commercial coming on. 2019 MY Disco 5 HSE Lux Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
THis a common transit problem apparently - i think something earlyones suffer Mike
Cheers MSE
So Ford sold all the duff ones to LR! I have 4 Duratorq transits and they are all fine, 1 x 2001, 1 x 2005, 1 x 2006 and 1 x 2007. We have had problems with Dual Mass Flywheels but not, as yet, turbos. They are all loaded permanently as we carry drain cleaning and surveying kit - all in at 3300 kg ![]() Both mine have failed under load, once towing a trailer up a hill and secondly when driving on motorway at 80 ish. So why are they OK in the Transits? I wish I knew! Frustrating as hell. 2019 MY Disco 5 HSE Lux Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
Youll never get a dual mass flywheel failure on a defender (they dont have them) Yes i dont know where i read it - but the turbo is a known (atleast by those that know!) a common Ford Transit failure just a quick search on google: http://www.google.co.uk/search?q=Transit+turbo+failure&hl=en but:
Maybe more interestingly - linked to the EGR?? Mike |
Andrew, it makes you wonder if the first turbo problem we have both had was down to a dodgy EGR and that is the reason mine has gone again. I spoke to Likes this week and they told me they had had their first EGR failure this week, I am guessing that was yours then! 2019 MY Disco 5 HSE Lux
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
Do you need the EGR value on the puma engine ??
I was having problems with EGR value on my td5 90, removed it and replaced with blanking plate. Solved all the problems and engine runs much better now ![]() Andrew on another matter - Did you have any balancing problems with ZU wheel tyre combination ? just got a set with BFG all terrains and used Dyna balancing, they wobbling all over the place above 50mph ? Nidge. |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
None at all. ATS ballanced my wheels using stick on weights. ![]() |
