![]() | Home > Puma (Tdci) > Oil service warning? |
| sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455
Can you please post the link to resetting oil service procedure as I've tried to find it and no luck
Cheers It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
The search facility is often your friend
http://www.defender2.net/forum/topic26474....vice+light Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179
Worked a treat for me 2013 Aintree Green 110 Station Wagon SX
| Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288
The service interval is 12,000 miles or 12 months; whichever is soonest.
So the 12,000 miles has not arrived, and I am assuming the 12 months is not up yet? Was your car a factory order or 1 from stock? If the car was a stock car the service light should be calibrated/reset at the pre delivery inspection, this may be when the car arrives at the dealer, not at point of delivery/collection. Regards Mark. |
| WAFU Member Since: 18 Jul 2013 Location: Devon Posts: 56
Hi Mark,
The car was in the show room so a stock item and Ive had it for around 6/7 months. I understand what you are saying My only other concern was Im sure I read somewhere that the engine somehow based its "oil service" reminder on style of driving/oil quality etc - I guess I got that wrong then Thanks alot |
With the higher speed driving style I would not be worried so much by DPF issues.
For the fact it was a showroom car I would imagine you have the answer - the service light was not reset before delivery - this is fairly common. The thing to check for on DPF cars is an increase of engine oil; i.e. contamination with diesel. This is not only bad for bearings - but if the level gets too high the engine can go for a little run on its own diesel/oil mixture; this is usually terminal!! That said I try and change mine every 6,000 miles - I intend to keep it! |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
The service indicators are set at the factory apparently, sometimes wrongly. Our Disco4 is flashing up 'Service Required' even though it's not even 6 months old yet. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Hello WAFU
I would get the Service Lights checked at LR, asap, if only for peace of mind. (especially as this vehicle is around 6 months old). I had a 300tdi 90 CSW from new and Serviced with LR until 60K, but changed the oil midway between each 12000 mile Service or each 1/2 year myself, I am convinced it's one of the best service steps to take. The 300tdi (1994) was actually taken back to LR for a oil change at 1500 miles, this practice is claimed to be now not necessary, but early ware and oil contamination can be negative factor. At this point of ownership consider changing the oil, irrespective of the type of driving you are doing. SKIP https://www.defender2.net/forum/topic83242.html |
