Home > Puma (Tdci) > strange whine noise from the back
pdv
Belgium 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Hy,
my defender from 2008 makes since 3 months a whine noise when slowing down to +/- 30km/h then it's back silence. After looking on some forums it's a problem with the rear diff. So changed my wheelbearings and fitted an ashcroft locker and new pinion bearings. this at 65 000 km but the noise is still there ? it's really awfull to hear it Crying or Very sad Crying or Very sad
someone with the same problem or tips ?
grtz
Tarcis
ps. sorry for my english it's not that good I am from Belgium Smile
Post #320384 30th Mar 2014 9:53pm
pdv
somebody ? Bow down Very Happy
Post #320778 1st Apr 2014 1:39pm
Happyoldgit
Have you checked the oil levels and free play in the rest of the driveline? Steve.
http://forums.lr4x4.com
Post #320783 1st Apr 2014 2:08pm
g-mack
sound travels around and can be deceiving! i had a vibration on back of my disco2 and changed lots of things on back axle! turned out to be front of rear prop uj!! i was convinced it was back axle related!! My 109 thread
my youtube channel
Post #320786 1st Apr 2014 3:06pm
Tiger
We get this with kids in the back Thumbs Up
Post #320787 1st Apr 2014 3:12pm
pdv
all is set up correctly, and the UJ's have no play Confused at 110km/h it sound like metal to metal at an high tone...
i readed on an Australian forum it's something with the ring an pinion that has been changed or something?
strange things those land rovers Laughing
Post #320818 1st Apr 2014 6:29pm
Whine is typically caused by sub-optimal meshing of the crownwheel and pinion. Did you rebuild the diff yourself? Are you sure that the pinion height was set correctly when the new bearings were put in? Was the crownwheel backlash set up correctly? Was the pinion/crownwheel contact pattern checked? Any errors here are likely to cause whine.
Are you sure it isn't tyre wear? Sometimes rotational wear irregularities (tread blocks worn more on the leading edge) can make whining noises, consider swapping the tyres from one side with the other to see if it makes a difference.
Post #320821 1st Apr 2014 6:38pm
Duplicate post, deleted.
Post #320822 1st Apr 2014 6:39pm
Triplicate post - deleted.
Post #320825 1st Apr 2014 6:42pm
AlanH
Australia
I had a strange "bag pipe" type noise which rose and fell then disappeared at various times at 97K and just before the warranty ran out.
The Cook thought it was gearbox area, I thought it was engine and an indy said it was the rear diff. So off to the stealer with a short list of things to be done under warranty and they said ....transfer box. At 97K they would normally install a recon box but there were none available anywhere so I got a new box instead.
No noise now and certainly no complaints from me about LRA and this stealers service.
AlanH.
Post #320966 2nd Apr 2014 2:54am
MK
Sometimes the pinion gets loose and therefore the proper mesh is gone. If not, maybe one of the bearings is gone. Puma 110" SW
Post #321000 2nd Apr 2014 10:39am
