![]() | Home > Puma (Tdci) > strange whine noise from the back |
pdv Member Since: 07 Feb 2014 Location: Asse Posts: 27 ![]() ![]() ![]() |
somebody ?
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Have you checked the oil levels and free play in the rest of the driveline? Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
sound travels around and can be deceiving! i had a vibration on back of my disco2 and changed lots of things on back axle! turned out to be front of rear prop uj!! i was convinced it was back axle related!! My 109 thread
my youtube channel |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
We get this with kids in the back
all is set up correctly, and the UJ's have no play
![]() i readed on an Australian forum it's something with the ring an pinion that has been changed or something? strange things those land rovers ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031 ![]() ![]() ![]() |
Whine is typically caused by sub-optimal meshing of the crownwheel and pinion. Did you rebuild the diff yourself? Are you sure that the pinion height was set correctly when the new bearings were put in? Was the crownwheel backlash set up correctly? Was the pinion/crownwheel contact pattern checked? Any errors here are likely to cause whine.
Are you sure it isn't tyre wear? Sometimes rotational wear irregularities (tread blocks worn more on the leading edge) can make whining noises, consider swapping the tyres from one side with the other to see if it makes a difference. |
Duplicate post, deleted.
Triplicate post - deleted.
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
I had a strange "bag pipe" type noise which rose and fell then disappeared at various times at 97K and just before the warranty ran out.
The Cook thought it was gearbox area, I thought it was engine and an indy said it was the rear diff. So off to the stealer with a short list of things to be done under warranty and they said ....transfer box. At 97K they would normally install a recon box but there were none available anywhere so I got a new box instead. No noise now and certainly no complaints from me about LRA and this stealers service. AlanH. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Sometimes the pinion gets loose and therefore the proper mesh is gone. If not, maybe one of the bearings is gone. Puma 110" SW
