Home > Puma (Tdci) > Pinion part number?
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
Pinion part number?
Greetings from Oz, just wondering if anyone can help me with the part number for the rear diff pinion oil seal for a 2010 puma. Local supplier here insisted it's STC4401 but that looks to be for the salsibury axle 99-02. The part numbers I can come up with is either FTC5258 or FRC8220. Which is the correct one? and what's the difference between the two?
Post #317791 21st Mar 2014 2:04pm
shaggydog
Give Dan At Duckworths a pm with your Vin number and he can look it up for you Thumbs Up
Cracking avatar btw Whistle
Post #317793 21st Mar 2014 2:06pm
Martin
Site Admin
Yes I know I'm a party pooper but not a suitable avatar, sorry.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #317795 21st Mar 2014 2:09pm
If it's a 110 or 130 the rear diff will be the P38-type unit with 4 differential gears (known mysteriously as a "4-pin" diff) and the seal is FTC4851.
I haven't checked the part numbers you quote but I suspect they're for the Rover pattern diff (as used in the rear of the 90), not the P38.
Post #317799 21st Mar 2014 2:23pm
MK
it is FTC4851 Puma 110" SW
Post #317812 21st Mar 2014 3:04pm
ozy013
ok, thanks for the advice. Now to chase down the part FTC4851.
Post #318070 22nd Mar 2014 11:27am
