![]() | Home > Maintenance & Modifications > Quick Question on Steering Dampers |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
I have the OME (for bigger wheels and off road) and the LR OE damper is perfectly good IMO Puma 110" SW
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
Standard wheels standard damper should be fine (not Sh*tpart) big wheels bigger damper OME, Bilstien etc.
Keith |
all my defenders I have always run 2 , one in front and one behind axle ( standard ones )
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
@munch90 - Do you have a photo of this setup?
don't have any pics
but standard set up in front of axle and one on the link rod ( between wheels ) behind axle mounted off the diff nose I found having one fitted behind is much more inline with link and more positive in stopping wheel wobble mainly bump steer because the front one is at a angle and not inline with front link you lose a bit of dampening effect |
