Home > Puma (Tdci) > Am I missing fuse
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
Am I missing fuse
Okay I may have missed a post about this already but I seem to have a fuse missing in the secondary fuse box (under dash) on the first row (right hand side) half way down. It has a picture of an engine with a electrical flash going across it, can not recall the fuse number. Any ideas if it should be missing and what it is for Question 90 & Wolf
110 XS
Previously owned SI SII SIIa SIII & Light weight (air portable)
Post #313008 2nd Mar 2014 10:20pm
Norm4n
Mine has one in that space
Post #313015 2nd Mar 2014 10:34pm
RustyM
Oh Censored Big Cry Anyone know what it is for and if I should put one in the gap Question Should have also said mine is a MY 2014 110 XS 2.2 90 & Wolf
110 XS
Post #313017 2nd Mar 2014 10:37pm
RustyM
Anyone Question 90 & Wolf
110 XS
Post #313227 3rd Mar 2014 9:29pm
Have you had a look in the handbook? As you've got a new vehicle and, presumably, everything works, there's probably not much to worry about. Darren
Post #313257 3rd Mar 2014 10:27pm
RustyM
Indeed I have looked but in true JLR fashion no informative information on fuses is present Exclamation I think all is functional but the engine is rough and is different every time it is driven from startup. I wondered if this missing fuse is in anyway related to this Question 90 & Wolf
110 XS
Post #313266 3rd Mar 2014 10:39pm
In that case, take it back to the dealer. Darren
Post #313272 3rd Mar 2014 10:42pm
RustyM
Thank you, but a dealer visit is not an option I have available to me right now. I am a fair few hundred miles and ferry journey away from one. I guess putting a fuse in the gap is worth a try.... What's the worst that could happen? 90 & Wolf
110 XS
Post #313279 3rd Mar 2014 10:49pm
Not much, really. If the fuse isn't needed then nothing will happen. If it is then you will have solved the problem (of the missing fuse - not necessarily the engine). Darren
Post #313281 3rd Mar 2014 10:54pm
A bit of digging for wiring doagrams with Google suggests that your missing fuse may be to provide power to the MAF, so it might well be the cause of your engine problems after all. Stick a 5 amp fuse in and see how it goes. Darren
Post #313288 3rd Mar 2014 11:11pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Shocked
When the dealer checked the car for delivery, shouldn't they have felt it wasn't sounding and feeling normal? MAF has quite en impact on how smooth your engine runs...
Post #313345 4th Mar 2014 9:12am
RustyM
Bow down I will get a fuse as to my astonishment there are no spare ones under the seat! I did have a box with some in but the roof box seems to have eaten them Whistle Once I have borrowed / stolen one from an unsuspecting donor I will test it. Thank you LR Anorak as it may well be why it is running rough if it is the MAF Thumbs Up 90 & Wolf
110 XS
Post #313565 4th Mar 2014 9:34pm
