![]() | Home > Puma (Tdci) > Am I missing fuse |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Mine has one in that space
RustyM Member Since: 28 Oct 2013 Location: Africa/The Med Posts: 222 ![]() ![]() ![]() |
Oh
![]() ![]() ![]() 110 XS Previously owned SI SII SIIa SIII & Light weight (air portable) |
Anyone
Have you had a look in the handbook? As you've got a new vehicle and, presumably, everything works, there's probably not much to worry about. Darren
Indeed I have looked but in true JLR fashion no informative information on fuses is present
In that case, take it back to the dealer. Darren
Thank you, but a dealer visit is not an option I have available to me right now. I am a fair few hundred miles and ferry journey away from one. I guess putting a fuse in the gap is worth a try.... What's the worst that could happen? 90 & Wolf
Not much, really. If the fuse isn't needed then nothing will happen. If it is then you will have solved the problem (of the missing fuse - not necessarily the engine). Darren
A bit of digging for wiring doagrams with Google suggests that your missing fuse may be to provide power to the MAF, so it might well be the cause of your engine problems after all. Stick a 5 amp fuse in and see how it goes. Darren
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
![]() When the dealer checked the car for delivery, shouldn't they have felt it wasn't sounding and feeling normal? MAF has quite en impact on how smooth your engine runs... |
