Home > Technical > transfer box ratios
sas pinkie
transfer box ratios
I have a 1988 csw fitted with defender 200tdi and gearbox and a discovery transfer box. I am running 750s.
being a genuine camel trophy vehicle which I am then adding to for camping trips (roof tent, fridge ect) it is a rather heavy 110 and I am struggling to keep to 60 on the slightest of inclines. I was in Gloucestershire a few weeks ago and a steep hill had me in first and nearly had to reach for low box. I think the disco transfer box is too much for it so want to go to the standard ratio transfer box for a 1991 -93 200tdi csw. what ratio box am I looking for and is there any indicator on the transfer case as to what ratio is contained within?
cheers
karl
Post #312828 2nd Mar 2014 10:29am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi the standard defender box is a 1.4 ratio and there is a label on them to indicate this. I also believe you can use the serial number to workout the gearing.
One thought though - as far as I am aware the transfer box ratios only really effect your take off in first gear and top end. If you are finding you have to change down going up hill, this won't necessarily improve with different ratios. In fact the only negative I have ever heard is that it can be difficult to get away at the lights if you are towing heavy loads with a 1.2 transfer box (and a TDI or non remapped TD5). Let's face it there are/were thousands of 200tdi discos out there that were OK?
Are you sure there is not an issue with your engine being down on power?
Post #312895 2nd Mar 2014 3:33pm
A Disco transfer box will affect all high range ratios.
Discoverys were fitted with smaller tyres than Defenders to offset the higher gearing. They're also significantly more aerodynamic, which makes a big difference above 50mph or so. Darren
Post #312897 2nd Mar 2014 3:40pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Are you absolutely sure the engine is running as well as it can? I would suggest checking it out, preferably on a rolling road before changing the drive train ratios. Changing the transfer box ratios is normally done to produce a higher top speed or lower revs for a set speed. It has no effect on engine power output and it would seem in your case either the engine is down on power or the vehicle is overloaded. Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #312902 2nd Mar 2014 4:15pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
You can get 1.1 1.2 1.4 1.6
Td5 defender run 1.4 standard all pumas run 1.2
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #312903 2nd Mar 2014 4:18pm
dnorrishill
Good point on the disco forgot about wheel sizes... Embarassed
Post #312959 2nd Mar 2014 7:25pm
excossack
What is standard Disco tyres? 205/16 or 235 / 16 ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #312967 2nd Mar 2014 7:53pm
Yes to both, depending year / spec. 235's will have a 70 aspect ratio, which is essentialy the same diameter as 205's. Darren
Post #312971 2nd Mar 2014 8:13pm
sas pinkie
well if the 110 is overloaded best have a word with land rover special vehicles, they specced and built it. it is currently unloaded and standard camel spec with the addition of a roof tent.
the 110 goes well once on the flat, had it above legal speed, but as soon as a slight incline is reached it just drops off. for this reason I believe the ratio is too high.
so a 200tdi has a 1.4 ratio transfer box? is this different to the earlier 2.5 diesel and turbo diesel? does a 90 have a different ratio to a 110?
Post #312981 2nd Mar 2014 8:43pm
Lou Sparts
I,ve owned 3 90,s all have had the 1.4 transfer box 1st was a Td, 2nd a 300Tdi,3rd a Td5.
I believe the N/A diesel had the 1.6 box,
Once knew a chap who put a 1.2 box in a N/A diesel 110 rendering 5th gear to downhill use only ! 2005 Td5 90 XS
Steve
Post #312982 2nd Mar 2014 8:51pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Could be more of a turbo problem or engine problem Wink Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #312995 2nd Mar 2014 9:55pm
Anderzander
I think you want the 1.4
A 200tdi doesn't really have the poke to pull a disco box. A friend is taking one out of his 90, to go back to the standard 1.4, for the same reasons.
Post #313016 2nd Mar 2014 10:35pm
