![]() | Home > My Defender > Rear LED Work light |
Your cable entry either needs sealing or a gland fitting or water will track in, it'll stop the cable chafing as well.
![]() http://www.indexmarine.co.uk/deck-glands-plastic.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 256 ![]() ![]() ![]() |
Very nice! Good work and I bet the work area gets bathed in virtual daylight.
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2791 ![]() ![]() |
Had the same fitted to mine as 'driving lights' that came on with high beam. They were brilliant but sadly they didn't last very long, got condensation inside pretty quickly and led's started failing in pairs. Got a year of good life out of then though and yours is probably in a better place to avoid being plunged into muddy water than on my bumper..
Good lights though, can only imagine what it's like looking at it at night! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Well spotted. I was expecting someone on this forum to point it out. The hole at the moment is so small, finding a grommet is tough... I did cut one down to size, but it didn't really work. I'll be sorting something out for it soon. Right after I fix my headlight switch which fell apart today. David - don't know what make this one is, but it's bloody heavy, I am reasonably confident it's a good one, but we'll see! ![]() |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 ![]() ![]() ![]() |
Hi Interlet
What model is this lamp, and where did you get it Thanks Gavin |
I'm afraid I don't know what make it is. I bought it from someone on this forum, who also didn't know. It is very bright and seems well built but only time will tell. This is just a. Standard 6 inch work light bar. I recently bought another 12 inch one from someone else on the forum, they are very similar. 1998 110 300Tdi White Hard Top
durite do one much the same
Thanks guys
BTW Interlet - does that lamp have an integral switch ?
Gavin |
Nope i had to fit one inside on the dash for it. 1998 110 300Tdi White Hard Top
