Home > My Defender > Rear LED Work light
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Rear LED Work light
Finally got round to installing my small LED light bar - the 6 inch jobby, not the recently acquired 12 inch bar, to use as a rear work light. Larger one, I will find somewhere on the front for it to go.
I drilled some holes through the roof rack, although the bolts were so close to the top rails of the rack, it was a bit of a struggle to get the nuts on...fortunately, once actually on, it did ensure the nuts did not move, while I nipped the bolts up.
I didn't upload the picture head on of the light, cause it's too bright!
 1998 110 300Tdi White Hard Top
Post #308761 16th Feb 2014 10:58pm
K9F
Your cable entry either needs sealing or a gland fitting or water will track in, it'll stop the cable chafing as well. Thumbs Up
http://www.indexmarine.co.uk/deck-glands-plastic.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #308781 16th Feb 2014 11:41pm
Egghead
Very nice! Good work and I bet the work area gets bathed in virtual daylight.
Post #308786 17th Feb 2014 12:00am
Cheshire110
Had the same fitted to mine as 'driving lights' that came on with high beam. They were brilliant but sadly they didn't last very long, got condensation inside pretty quickly and led's started failing in pairs. Got a year of good life out of then though and yours is probably in a better place to avoid being plunged into muddy water than on my bumper..
Good lights though, can only imagine what it's like looking at it at night! Cheers, David
Post #308790 17th Feb 2014 12:38am
Interlet
Well spotted. I was expecting someone on this forum to point it out. The hole at the moment is so small, finding a grommet is tough... I did cut one down to size, but it didn't really work. I'll be sorting something out for it soon. Right after I fix my headlight switch which fell apart today.
David - don't know what make this one is, but it's bloody heavy, I am reasonably confident it's a good one, but we'll see! Twisted Evil 1998 110 300Tdi White Hard Top
Post #309055 18th Feb 2014 1:22am
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Hi Interlet
What model is this lamp, and where did you get it
Thanks
Gavin
Post #309884 20th Feb 2014 12:21pm
Interlet
I'm afraid I don't know what make it is. I bought it from someone on this forum, who also didn't know. It is very bright and seems well built but only time will tell. This is just a. Standard 6 inch work light bar. I recently bought another 12 inch one from someone else on the forum, they are very similar. 1998 110 300Tdi White Hard Top
Post #309890 20th Feb 2014 12:41pm
munch90
durite do one much the same
Post #309893 20th Feb 2014 1:01pm
gavinpm
Thanks guys
Post #309897 20th Feb 2014 1:18pm
gavinpm
BTW Interlet - does that lamp have an integral switch ?
Gavin
Post #309900 20th Feb 2014 1:26pm
Interlet
Nope i had to fit one inside on the dash for it. 1998 110 300Tdi White Hard Top
Post #309924 20th Feb 2014 2:48pm
