Home > Technical > Discs and callipers
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Discs and callipers
I have a perfect spare set of solid discs, callipers and pads from my 2006 Td5, does anyone know if they will fit onto my 1989 2.5td?
I can't get at the older truck at the moment, it's not at my place and I'm on the way to collect some new brakes for it early in the morning, seems a shame to not use them if they'll fit - but I have to be certain.
Post #305396 5th Feb 2014 9:14pm
Lou Sparts
Solid discs on a 2006 Td5 ? my Td5 is 2005 and has vented discs ! 2005 Td5 90 XS
Steve
Post #305399 5th Feb 2014 9:17pm
Lambley
They are definitely solid, I changed them for 110 vented discs and callipers about 9 months ago.
Post #305401 5th Feb 2014 9:24pm
Lou Sparts
I must admit to being a little suprised when i first took my front wheels off when i first bought mine and found vented discs i thought they only went on 110,s.
Were they an option ? do you get them on a station wagon and not a commercial ? Anyone know ? 2005 Td5 90 XS
Steve
Post #305404 5th Feb 2014 9:29pm
Lambley
Maybe it was an option, you might have just been lucky and somebody had replaced them it does improve the braking a fair bit, but the last 2 Defender I have had (2004 and 2006) have both had solid discs.
Anyway... anybody know if they'll fit?!!
Post #305405 5th Feb 2014 9:33pm
Lou Sparts
More likely the factory ran out of solid discs that day and just fitted everything with vented Rolling Eyes 2005 Td5 90 XS
Steve
Post #305410 5th Feb 2014 9:39pm
jimbob7
Front or rear,90 or 110, I think 90's had solids on the front and 110 should be vented on the front solid rears.Not sure from when,earliest would be 300 when they put discs on the rears,i guess. Pov.spec,ftw. 2006, 110,TD5.
Post #305419 5th Feb 2014 9:51pm
GUM97
Pretty sure it'd have rear drums on a vehicle of that age? A mate of mine has a 1990, and that has drums on. An engine to TDi for!
Post #305432 5th Feb 2014 10:32pm
Lambley
Sorry if there was any confusion - I was only talking about the fronts, the discs and pads on the 1989 Defender are pretty shot, so....
I have a spare pair of front discs, pads and callipers from my 2006 Defender and wondered if they will fit the older 1989 model, the drums on the rear are getting sorted.
Post #305436 5th Feb 2014 10:37pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Yes, the later TD5 discs and calipers will fit your earlier Defender without a problem. Smile
Post #305445 5th Feb 2014 10:54pm
Lambley
Brill, good news Thumbs Up
I'm not a tight wallet but they are just sitting on the shelf in my garage.
Thanks for the replies. My 2006 Td5 had solid discs until I upgraded them with new callipers and vented discs from a 110, not a massive improvement over the solid ones but definitely better.
Post #305453 5th Feb 2014 11:04pm
grafty99
I put 110 vented fronts and 110 rears on my 90. With braided hoses, stops very well now Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #305471 5th Feb 2014 11:37pm
Lambley
Grafty - did you try the brakes before and after the braided hoses were fitted or do it all in one go? I just wondered how much difference they make?
Post #305474 5th Feb 2014 11:45pm
jimbob7
Braided hoses on a motorbike are a massive improvement over standard rubber,it's a mod I have lined up for mine. Pov.spec,ftw. 2006, 110,TD5.
Post #305481 5th Feb 2014 11:57pm
grafty99
Unfortunately I did it all at once as my old discs and calipers were shot.
There is, however, much more feel to the brakes. You can brake really hard and know when you're about to lock up, whereas with the rubber hoses you would brake hard but not quite know when you were going to lock up so you ended up not using the brakes to their full potential. Also, because the 110 rear calipers are larger, when you brake hard - instead of the front diving down and the rear going skittish the whole thing hunkers down and is really stable under braking.
How much of this is down to the braided hoses I don't know, but the braking feel is much improved over the originals and I would defiantly reccomend them Thumbs Up
Gave me much more confidence to brake hard in the wet too.
Ps. non abs 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #305650 6th Feb 2014 6:45pm
