![]() | Home > Technical > Discs and callipers |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Yes I put 110 callipers on the rear, the whole calliper is bigger
46 mm pistons as apposed to 41 mm and the pads are considerably larger. Definitely go for braided hoses ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Just to clarify, 110 rear callipers on the rear of my 90
mpb Member Since: 30 Sep 2013 Location: Stafford Posts: 15 ![]() ![]() ![]() |
Are the 110 discs the same size as the 90, as I need to put new callipers on my 90 and 110 ones would be much better.
Many thanks Martin |
I'm not 100% sure! I think the difference is in the off set of the disc rather than the diameter of it. But with fettling a 110 caliper should fit a 90 disc but please don't curse me if it doesn't
Sorry, I assume we're talking rears? The fronts are the same, only deference being vented or not
Many thanks for that, it was the rear I was thinking of.
I'll have to get under the other halls 110 with a tape measure if it ever stops raining. Cheers Martin |
