![]() | Home > My Defender > better breathing |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596
Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
With the Puma there has been much discussion and debate about filters, contamination of MAF and various other niggles. I too have an ITG filter but a standard fit one that sits in the OEM box. Nice bit of kit and one that has not given me any hassle.
Yours does look cooler too. Treat every day as if it is your last....one day you will be right!! |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Have to say that is a beautiful looking 300... Wonder how it compares to the HS 2.8L TGV version of the 300...!??!
I looked at the 2.8 TGV before deciding to rebuild the 300 with a few improvements.
When it comes time to get a new engine/rebuild again I think I will be speaking to IRB about their blueprinted 300Tdi unit. A 2.8 is tempting but with production ended I have a concern about spares etc. From what I have heard it is a good unit though. |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Would be interesting to see with a cold air feed connected to a snorkel.
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Yep - I did a test with my Puma, comparing taking air from outside with inside the engine compartment - pretty horrifying results under certain conditions (amazing how quickly the temperature in the engine compartment changes). Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
| g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967
looks good!
did you fit the clear header tank? or was it already on. anyone know where to get one. had a look on ebay and they dont look see through! My 109 thread my youtube channel |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
Alex - looks good.
I had a one of the prototypes of this - just never got round to fitting it/doing a kit. I would get a cold air feed to it though... at the moment you will be sucking in warm air. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Would a bonnet like this help:
http://www.mlrc.org.uk/MLRCforum/index.php?topic=909.0 ? Might look a bit OTT though But shout it at them in German because life is also terrifying and confusing... |
Don't look the best in my opinion - and the scoop is the wrong way round...
A forward scoop is ideal to force air into a top mounted intercooler - but a forward facing scoop feeding straight into the underbonnet area messes up under bonnet air pressure and can reduce air flow though the intercooler and/radiator. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
So LR's design of sucking air through the wing side isn't so bad then
Thanks for the comments guys.
Gmack - the header tank is an Allmakes one that I bought. I think anywhere that supplies AllMakes should be able to sell you one. I think it was £20. Ian - I may need to get one of those 102mm air intakes that fir the side vent that you have. |
| All times are GMT |
