Home > My Defender > better breathing
Alex1976
better breathing
I rebuilt my 300Tdi a year ago with a Turners Performance head and a VGT from Bell Auto Services. Performance was much improved and it was lovely to drive but I could help feeling the engine was a little restircted.
After my sucessful improvements with the new stainless steel striaght through exhaust I turned my attention to improving the intake. After reading the thread on modifying the intake box on Puma's and Ian's 102mm intake pipe mod I was convinced I needed to come up with something to improve the breathing on my 300Tdi.
After a bit of searching I have found this air box from ITG. It is a lovely high quality aluminum air box with an ITG foam filter inside.
It fits the standard 300Tdi mountings although I did line the inside of the straps with some self adhesive foam to protect the air box and give a snug fit for it.
It has a 102mm induction trumpet so I can run a cold air feed to it.
It gives lovely free breathing and still nice and quiet. Really pleased with this mod.
[/img]
Post #303747 31st Jan 2014 3:34pm
Alex1976
Post #303750 31st Jan 2014 3:40pm
Alex1976
Post #303751 31st Jan 2014 3:41pm
Alex1976
Post #303753 31st Jan 2014 3:43pm
K9F
With the Puma there has been much discussion and debate about filters, contamination of MAF and various other niggles. I too have an ITG filter but a standard fit one that sits in the OEM box. Nice bit of kit and one that has not given me any hassle.
Thumbs Up
Yours does look cooler too. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #303774 31st Jan 2014 4:39pm
geobloke
Have to say that is a beautiful looking 300... Wonder how it compares to the HS 2.8L TGV version of the 300...!??!
Post #303776 31st Jan 2014 4:45pm
Alex1976
I looked at the 2.8 TGV before deciding to rebuild the 300 with a few improvements.
When it comes time to get a new engine/rebuild again I think I will be speaking to IRB about their blueprinted 300Tdi unit.
A 2.8 is tempting but with production ended I have a concern about spares etc. From what I have heard it is a good unit though.
Post #303786 31st Jan 2014 5:19pm
Would be interesting to see with a cold air feed connected to a snorkel.
Post #303838 31st Jan 2014 6:39pm
ZeDefender
Yep - I did a test with my Puma, comparing taking air from outside with inside the engine compartment - pretty horrifying results under certain conditions (amazing how quickly the temperature in the engine compartment changes). Tell someone you love them today because life is short.
Post #303844 31st Jan 2014 6:51pm
g-mack
looks good!
did you fit the clear header tank? or was it already on. anyone know where to get one. had a look on ebay and they dont look see through! My 109 thread
my youtube channel
Post #303870 31st Jan 2014 8:09pm
Porny
Site Sponsor
Alex - looks good.
I had a one of the prototypes of this - just never got round to fitting it/doing a kit.
I would get a cold air feed to it though... at the moment you will be sucking in warm air.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #303902 31st Jan 2014 9:53pm
ZeDefender
Would a bonnet like this help:
http://www.mlrc.org.uk/MLRCforum/index.php?topic=909.0
Might look a bit OTT though Whistle Tell someone you love them today because life is short.
Post #303913 31st Jan 2014 10:15pm
Porny
Site Sponsor
Don't look the best in my opinion - and the scoop is the wrong way round...
A forward scoop is ideal to force air into a top mounted intercooler - but a forward facing scoop feeding straight into the underbonnet area messes up under bonnet air pressure and can reduce air flow though the intercooler and/radiator. IRB
Post #303920 31st Jan 2014 10:26pm
ZeDefender
So LR's design of sucking air through the wing side isn't so bad then Wink Tell someone you love them today because life is short.
Post #303927 31st Jan 2014 10:45pm
Alex1976
Thanks for the comments guys.
Gmack - the header tank is an Allmakes one that I bought. I think anywhere that supplies AllMakes should be able to sell you one. I think it was �20.
Ian - I may need to get one of those 102mm air intakes that fir the side vent that you have.
Post #303942 31st Jan 2014 11:28pm
