Home > Technical > What white is the right white..........
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I've just bought an N reg 90 300tdi to tinker with and it is white.
It needs a bit of, er, TLC to say the least and needs the paint re-doing in some areas. What shade / paint code would it be, I can't imagine that they did any more than one shade of white back then?
Searches on here haven't been conclusive.
Thanks
Dave
Post #303320 30th Jan 2014 1:54am
Cheshire110
Paint code should be printed under the bonnet, either at the front near the bonnet catch or near the brake fluid reservoir on the left as you look from the front.
You can then google "land rover paint code XXX" and I'm sure the answer will come up. Cheers, David
Post #303321 30th Jan 2014 1:59am
JeremyJ
Chawton white should be the one for a 300 but PM the last of your vin and I'll check for you
Post #303325 30th Jan 2014 7:54am
