![]() | Home > Technical > What white is the right white.......... |
| Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2791
Paint code should be printed under the bonnet, either at the front near the bonnet catch or near the brake fluid reservoir on the left as you look from the front.
You can then google "land rover paint code XXX" and I'm sure the answer will come up. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
| JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758
Chawton white should be the one for a 300 but PM the last of your vin and I'll check for you
