Home > Td5 > so mantec causes a power drop but......
sandylands
Hi, after sum tit decided to plough through a flood that I was Slowely going through flooding my poor td5 air filter, I've decided on a snorkel...also I like the look!! Now searching on here shows the mantec as a bit of a flop as it reduces power but what about the safari or safari copies?? Are they more free flowing?? Is the powermloss on the td5 aswell as the puma engines? I've done. A search and couldn't find anything so sorry I'm advance if its been covered
Many thanks
Post #301306 22nd Jan 2014 8:11pm
GUM97
I think in general all snorkels have some effect on power! It should be worth noting though that the Mantec is a Raised Air Intake rather than a snorkel, so a Safari Snorkel may be your best bet Thumbs Up An engine to TDi for!
Post #301307 22nd Jan 2014 8:18pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
It may have an influence on power, however not as much of an influence as an air box full of water... Laughing YOLO
1992 Defender 90"
1972 Lightweight 88"
Post #301319 22nd Jan 2014 8:29pm
sandylands
Exactly my thinking!! I don't really wade but it's just a precaution, feel very nervous since my incident. Snorkeld my old 200tdi after a similar incident!! But I simply ran a pipe up a cvheap metal mushroom top from rebel. Yeah that's what I read about mantec although I confess to liking the look not mention price!! But loosing 10hp as b.a.s showed on his dyno is a fair bit to drop. Fingers crossed safari isn't quite as bad!!
Thanks for the replys
Post #301359 22nd Jan 2014 9:52pm
sandylands
Just as a side note does anyone have experiance with the safari style from direct 4x4. I know safari genuine will be stronger but how strong do they need to be??
Post #301362 22nd Jan 2014 9:58pm
Ruari
2000 Defender 110 Td5 HT Alpine White
I have the safari copy fitted. Seems to be pretty solid.
Had to enlarge the bolt holes on the wing. Other than that an easy fit.
Siliconed all my hoses and drain holes. Later opened the drain on air box for rain water knowing I will never go that deep.
If I stick a poly bag over the head of the snorkel engines dies almost instantly. So it must be well sealed.
I did find and have found on other TD5's that the air intake connections inside the wing are loose and lower than the height on the wing.
Post #301443 23rd Jan 2014 10:26am
adseybear
Canada
There was certainly no noticeable power drop when I fitted a safari snorkel to my td5 90. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #301696 24th Jan 2014 9:41am
sandylands
Just to update, the safari snorkel on my 90 ends affect low down power and anti stall. Bum. Now I have a deeper problem, my snorkel was a safari copy that was a gift from the family including one extremely landrover obsessed 4 year old and I can't really remove it lol. Honestly it would be an easier decision to remove a testy than see his face after I remove his present to me and my landy. So question is- can I just drill the air box to gain performance?? I'm honestly never going to wade anywhere near bonnet deep so it should be perfectly fine from water. A bit of a strange one I know but does anyone have any thoughts on this or anyone even tried this??
Post #304685 3rd Feb 2014 1:41pm
"a bit of a strange one" is an understatement Shocked Shocked Shocked
Drilling holes would be a bad idea - you would have to drill quite a few and to quite a size to get any appreciable airflow and then that air will be coming from inside a warm/hot engine bay which will not do any favours to that missing power you are looking for.
What exactly are the issues you are experiencing with the snorkel?
If you can't live with them then I'd just man up and sit your 4 year old down and explain some simple fluid dynamics.
Maybe even draw him a picture Thumbs Up
Post #304712 3rd Feb 2014 4:24pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
Laughing that should keep him quiet for a few years!
Post #304715 3rd Feb 2014 4:35pm
SailingTom
Love the simple diagram Wink
I had a genuine safari on my first td5 and noticed no difference. It might be worth seeing if the top is smaller on yours as maybe you can get a genuine safari top or make up a bigger one?
Worth a go and saves messing the whole instillation up with holes . Defender puma dormobile camper
Post #304760 3rd Feb 2014 6:49pm
sandylands
Hmm lots to think about. I will try again tomorrow and see if I can live with the poor anti stall and sluggish when cold behaviour. Just as a point I found my safari knock off to have a wider diameter pipe than the original
Post #304800 3rd Feb 2014 8:15pm
Lou Sparts
Sluggish when cold ! sounds like a MAF issue. 2005 Td5 90 XS
Steve
Post #304803 3rd Feb 2014 8:34pm
mk1collector
As above^^^ might be worth unplugging the MAF and driving about for a couple of days to see if it cures some of your problems
Post #304809 3rd Feb 2014 8:43pm
sandylands
Hmmm, I did recently replace maf with genuine to try cure an odd starting issue, which it didn't. I'm really beginning to think the maf is better disconnected. Actually it was new before some moisture got into the airbnox, would a small amount of moisture damage a maf??
Post #304869 3rd Feb 2014 11:07pm
