Home > Td5 > so mantec causes a power drop but...... |
I think in general all snorkels have some effect on power! It should be worth noting though that the Mantec is a Raised Air Intake rather than a snorkel, so a Safari Snorkel may be your best bet An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
22nd Jan 2014 8:18pm |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
It may have an influence on power, however not as much of an influence as an air box full of water... YOLO
1992 Defender 90" 1972 Lightweight 88" |
22nd Jan 2014 8:29pm |
sandylands Member Since: 07 Nov 2012 Location: uk Posts: 19 |
Exactly my thinking!! I don't really wade but it's just a precaution, feel very nervous since my incident. Snorkeld my old 200tdi after a similar incident!! But I simply ran a pipe up a cvheap metal mushroom top from rebel. Yeah that's what I read about mantec although I confess to liking the look not mention price!! But loosing 10hp as b.a.s showed on his dyno is a fair bit to drop. Fingers crossed safari isn't quite as bad!!
Thanks for the replys |
22nd Jan 2014 9:52pm |
Just as a side note does anyone have experiance with the safari style from direct 4x4. I know safari genuine will be stronger but how strong do they need to be??
22nd Jan 2014 9:58pm |
Ruari Member Since: 10 Dec 2013 Location: Ayrshire Posts: 50 |
I have the safari copy fitted. Seems to be pretty solid.
Had to enlarge the bolt holes on the wing. Other than that an easy fit. Siliconed all my hoses and drain holes. Later opened the drain on air box for rain water knowing I will never go that deep. If I stick a poly bag over the head of the snorkel engines dies almost instantly. So it must be well sealed. I did find and have found on other TD5's that the air intake connections inside the wing are loose and lower than the height on the wing. |
23rd Jan 2014 10:26am |
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 260 |
There was certainly no noticeable power drop when I fitted a safari snorkel to my td5 90. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
24th Jan 2014 9:41am |
Just to update, the safari snorkel on my 90 ends affect low down power and anti stall. Bum. Now I have a deeper problem, my snorkel was a safari copy that was a gift from the family including one extremely landrover obsessed 4 year old and I can't really remove it lol. Honestly it would be an easier decision to remove a testy than see his face after I remove his present to me and my landy. So question is- can I just drill the air box to gain performance?? I'm honestly never going to wade anywhere near bonnet deep so it should be perfectly fine from water. A bit of a strange one I know but does anyone have any thoughts on this or anyone even tried this??
3rd Feb 2014 1:41pm |
"a bit of a strange one" is an understatement
Drilling holes would be a bad idea - you would have to drill quite a few and to quite a size to get any appreciable airflow and then that air will be coming from inside a warm/hot engine bay which will not do any favours to that missing power you are looking for. What exactly are the issues you are experiencing with the snorkel? If you can't live with them then I'd just man up and sit your 4 year old down and explain some simple fluid dynamics. Maybe even draw him a picture Click image to enlarge |
3rd Feb 2014 4:24pm |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 |
that should keep him quiet for a few years!
3rd Feb 2014 4:35pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1709 |
Love the simple diagram
I had a genuine safari on my first td5 and noticed no difference. It might be worth seeing if the top is smaller on yours as maybe you can get a genuine safari top or make up a bigger one? Worth a go and saves messing the whole instillation up with holes . Defender puma dormobile camper |
3rd Feb 2014 6:49pm |
Hmm lots to think about. I will try again tomorrow and see if I can live with the poor anti stall and sluggish when cold behaviour. Just as a point I found my safari knock off to have a wider diameter pipe than the original
3rd Feb 2014 8:15pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Sluggish when cold ! sounds like a MAF issue. 2005 Td5 90 XS
Steve |
3rd Feb 2014 8:34pm |
As above^^^ might be worth unplugging the MAF and driving about for a couple of days to see if it cures some of your problems
3rd Feb 2014 8:43pm |
Hmmm, I did recently replace maf with genuine to try cure an odd starting issue, which it didn't. I'm really beginning to think the maf is better disconnected. Actually it was new before some moisture got into the airbnox, would a small amount of moisture damage a maf??
3rd Feb 2014 11:07pm |
