|  | Home > Off Topic > Painting plastic.... what to use? |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | D J,
 Plastikote is very resilient against weather and moisture ingress and I have used it on window catches and lightguards on my Defender. It covers extremely well and with the primer you can apply a lot of coats in a very short time 10 minutes if I can recall between coats. Unaware how good it is against abrasions but would imagine a matt finish would not be the way to go.  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  19th Jan 2014 7:18pm |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | Cheers Mal
 Is that aerosol or hand paint you used? | ||
|  19th Jan 2014 7:21pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | In a can that goes 'psssssssst' when you press the button. Who are you calling an aerosol?     I am naturally heavy handed and usually make a hash of spraying but with this stuff even I got a perfect finish as it dries before you can apply too much and it runs. The fact you can apply so many coats in such a short time also means you can build up the primer to mask any imperfections/repairs. You will obviosly need to 'key' the surface if it is currently smooth or the Plastikote can be removed like a sheet afterwards!  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  19th Jan 2014 7:28pm |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435      | Rather than painting....
|  19th Jan 2014 7:31pm |
| redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243      | Halfords do plastic paint in different colours in aerosol cans. Sticks and wears well. | ||
|  19th Jan 2014 8:12pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | B & Q also have a varied selection and stock Plastikote and other plastic coating paints too.    If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  19th Jan 2014 8:19pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | I'd use acid etch for rigid plastics for it's etching properties into the plastic.
 If it's anything with any flex in it at all then you need a plastic primer. So primer, base colour coat and then a clear protection coat. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ | ||
|  19th Jan 2014 9:52pm |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | Cool, cheers all for the advice.
 It's a Honda quad i've bought, for a bit of wheeler-dealering money making. The engine needs some TLC, but the rest is fairly sound. It's been on a farm all its life (well, several farms), so naturally all the lights have gone AWOL, although it was road legal at one point, so shouldn't be too hard ro re-instate it. I was in two minds whether to vinyl wrap the platic in realtree type stuff. A good friend of mine has a couple of quads in this and it looks good, although they were built like that... my effort would probably look like i'd actually hit a tree, so coating the bright red Honda finish is probably the way forward. | ||
|  20th Jan 2014 7:43am |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422    | What would be the correct type of paint to use on the engine bay plastics as I would like to colour match these and the door mirrors. | ||
|  31st Jan 2014 8:23pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
