Home > Off Topic > Painting plastic.... what to use?
I need to paint (well, maybe, unless I vinyl wrap) some quad bike plastics.
It's a Honda, so bright Honda red. Is there a decent paint that will:
a) cover well (it's 20 odd years old, so has some scuffs etc that I can sand out)
b) cover some repairs I need to make (some splits which I'll fill/bond with tigerseal
c) be tough enough to last.
I was thinking some kind of plasticoat, but wanted it to be a bit thicker than just using a rattle can... or will that do ok?
Post #300336 19th Jan 2014 7:23pm
K9F
D J,
Plastikote is very resilient against weather and moisture ingress and I have used it on window catches and lightguards on my Defender. It covers extremely well and with the primer you can apply a lot of coats in a very short time 10 minutes if I can recall between coats. Unaware how good it is against abrasions but would imagine a matt finish would not be the way to go.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #300351 19th Jan 2014 8:18pm
Cheers Mal
Is that aerosol or hand paint you used?
Post #300353 19th Jan 2014 8:21pm
K9F
In a can that goes 'psssssssst' when you press the button. Who are you calling an aerosol? Rolling with laughter
I am naturally heavy handed and usually make a hash of spraying but with this stuff even I got a perfect finish as it dries before you can apply too much and it runs. The fact you can apply so many coats in such a short time also means you can build up the primer to mask any imperfections/repairs.
You will obviosly need to 'key' the surface if it is currently smooth or the Plastikote can be removed like a sheet afterwards!
Post #300358 19th Jan 2014 8:28pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Rather than painting....
Post #300362 19th Jan 2014 8:31pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Halfords do plastic paint in different colours in aerosol cans. Sticks and wears well.
Post #300381 19th Jan 2014 9:12pm
K9F
B & Q also have a varied selection and stock Plastikote and other plastic coating paints too. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #300385 19th Jan 2014 9:19pm
I'd use acid etch for rigid plastics for it's etching properties into the plastic.
If it's anything with any flex in it at all then you need a plastic primer.
So primer, base colour coat and then a clear protection coat. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #300432 19th Jan 2014 10:52pm
Cool, cheers all for the advice.
It's a Honda quad i've bought, for a bit of wheeler-dealering money making. The engine needs some TLC, but the rest is fairly sound.
It's been on a farm all its life (well, several farms), so naturally all the lights have gone AWOL, although it was road legal at one point, so shouldn't be too hard ro re-instate it.
I was in two minds whether to vinyl wrap the platic in realtree type stuff. A good friend of mine has a couple of quads in this and it looks good, although they were built like that... my effort would probably look like i'd actually hit a tree, so coating the bright red Honda finish is probably the way forward.
Post #300492 20th Jan 2014 8:43am
martinfiattech
What would be the correct type of paint to use on the engine bay plastics as I would like to colour match these and the door mirrors.
Post #303887 31st Jan 2014 9:23pm
