|  | Home > Off Topic > Extending wireless network |
| party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311      | Thanks again all,
 I've managed to find the old router so will have a go at configuring that as a WAP first of all. The solwise kit looks good though and could come in handy for a couple of other ideas for the future. Jon - 110 td5 [sold]. Currently Defenderless. | ||
|  18th Jan 2014 12:18pm |
| Alicat Member Since: 25 Nov 2013 Location: Hertfordshire Posts: 143    | Thumbs up for Devolo if you can't get the extra WAP sorted   | ||
|  18th Jan 2014 12:31pm |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | my 2p ..
 I have devolo, 200 and 500 mb versions, there are 1,2 and 3 socket versions and some even have wifi built in. It's easy to encrypt the data too The wifi model has an on/'off button on it Other than the encryption, they are pretty much plug and play PC world stock them but maplin are cheaper and usually have in stock | ||
|  18th Jan 2014 12:52pm |
| party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311      | UPDATE : Job jobbed    Took no time at all and even found the right 'how to' for my spare router on the net. Super coverage around the whole house now using two SSIDs Thanks all again for the input  Jon  - 110 td5 [sold].  Currently Defenderless. | ||
|  18th Jan 2014 1:22pm |
| AndyS Member Since: 18 Aug 2012 Location: London Posts: 597      | To add to what's been said, have a long term plan to run conduit sunken into the wall from the loft into every room that might require an internet connection. Then run conduit from wherever your internet feed is up into the loft and lay CAT5 cables to everywhere. You know they'll come a point when everything plugs into the internet (the Internet of Things) so might as well have a long term plan to make your house compatible with it.
 It's a bit job if you do it all at once but cheap. It's what I've been doing for the past ten years and now everything is hard wired to the router. I get 60mbps on the computers, no drop outs, no back spots and the added bonus of network backup drives to save everything to or view/listen to things from. The only things that connect to the WI-FI are the phones. | ||
|  18th Jan 2014 4:41pm |
| danridge Member Since: 28 May 2013 Location: Bath Posts: 438      | Monkey - good job and no £'s parted with   You should be able to run a single SSID from both routers and your devices will auto switch between them.  I have that setup here. | ||
|  18th Jan 2014 5:15pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
