Home > Maintenance & Modifications > Dashboard out. What (other) things to do?
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
I want to connect my external spots (Nolden- LED's) to originaliteit switches in my dashboard. I tried to fidle a loom through without removing the complete dash. Finaly I removed the dash, as it didn't work out.
Now it is off, what other works should I consider?
I thought of adding extra 12v sockets and a map light myselve.
Sugestions apriciated.
Q.
Post #299228 15th Jan 2014 11:39pm
g-mack
dynamating? or some other extra sound barrier. My 109 thread
my youtube channel
Post #299238 16th Jan 2014 12:45am
Cheshire110
The remote locking range improvement thing? Sure someone will know the tread on here detailing it Cheers, David
Post #299241 16th Jan 2014 12:56am
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Twin washer jets.
Anti corrosion treatment in any cavities.
Any pictures? http://defender90xs.blogspot.co.uk/
Post #299258 16th Jan 2014 7:36am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I would be putting a bead of sikaflex or something along the back of the windscreen - bulkhead seal as is has to go sometime.
Rustproof everything.
Dynamat.
Extra Foam
Have you thought about if you ever add additional lights or extras you could run a 5 core from the switch console and leave it coiled up behind the drivers speaker? William
Post #299284 16th Jan 2014 10:26am
While the dash is off you might want to make sure that the wiper rack and wheelboxes are properly lubricated, and also consider some anti-theft measures on the 10AS and OBDsocket.
Post #299289 16th Jan 2014 10:48am
mark_d wrote:
Any pictures?
An extensive set of dash-out photos can be found here - you may need to scroll both back and forward through the pics.
Post #299291 16th Jan 2014 10:52am
rossy
Bow down Gulp ! What brave clever chaps you are. I would so not attempt that !
Post #299296 16th Jan 2014 11:10am
JWL
+1 for the twin washers Thumbs Up
Post #299309 16th Jan 2014 12:52pm
mark_d
blackwolf wrote:
mark_d wrote:
Any pictures?
Excellent - Thank you.
No expense spared on the factory sound proofing. http://defender90xs.blogspot.co.uk/
Post #299448 16th Jan 2014 10:28pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
Wiper park switch, common and fiddly with dash in but easy with it out
Post #299753 17th Jan 2014 9:47pm
