![]() | Home > Maintenance & Modifications > Dashboard out. What (other) things to do? |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
dynamating? or some other extra sound barrier. My 109 thread
my youtube channel |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
The remote locking range improvement thing? Sure someone will know the tread on here detailing it Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
Twin washer jets.
Anti corrosion treatment in any cavities. Any pictures? http://defender90xs.blogspot.co.uk/ |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
I would be putting a bead of sikaflex or something along the back of the windscreen - bulkhead seal as is has to go sometime.
Rustproof everything. Dynamat. Extra Foam Have you thought about if you ever add additional lights or extras you could run a 5 core from the switch console and leave it coiled up behind the drivers speaker? William |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17913 ![]() ![]() ![]() |
While the dash is off you might want to make sure that the wiper rack and wheelboxes are properly lubricated, and also consider some anti-theft measures on the 10AS and OBDsocket.
An extensive set of dash-out photos can be found here - you may need to scroll both back and forward through the pics. |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
+1 for the twin washers
Excellent - Thank you. No expense spared on the factory sound proofing. http://defender90xs.blogspot.co.uk/ |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
Wiper park switch, common and fiddly with dash in but easy with it out
