Home > Technical > Crossmember mounting
x-isle
Something I only noticed today is the extra 4 bolts on a 90 crossmember that a 110 doesn't have.
I assume it's just the way the body is mounted, but what is it?
You can see the extra 4 bolts on the outside edges of the crossmember.
I realise this is common knowledge, but as I've never owned a 90, I didn't realise they existed.
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #299014 15th Jan 2014 1:01pm
Cheshire110
i **think** someone on here mentioned seatbelt mounting brackets or something of that sort? sure i saw these mentioned in topics about fitting rear seats to a 90HT, but i stand corrected if someone knows better.
they're not present on a 90 HT (at least they weren't on my '58 plate 90 county hard top 2.4) so that indicates seats to me? Cheers, David
Post #299020 15th Jan 2014 1:12pm
Likeomg
its what the seat belts bolt to, its a bracket thing
Post #299021 15th Jan 2014 1:15pm
mk1collector
My 110 has them
Post #299023 15th Jan 2014 1:16pm
x-isle
That makes sense than.
I guess a 110 7 seater has them. Craig Rogers
2007 Puma 110 XS
Post #299035 15th Jan 2014 1:44pm
JWL
Yep, 110's with the factory fit bench seats have them fitted, and aren't they a pain in the arris when you want to fit bumperettes Rolling Eyes
Post #299062 15th Jan 2014 3:41pm
GUM97
^^A pain is an understatement! Laughing An engine to TDi for!
Post #299088 15th Jan 2014 5:44pm
ericvv
Correct. Here you see them on my 7 seater, they were painted black together with the rear crossmember.
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #299153 15th Jan 2014 8:10pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Eric, did you hammerite your kaymar carrier? Mine's rusting like a good'un. Needs to be blasted, Galv'd and coated with something...Not quite decided what!
Post #299157 15th Jan 2014 8:20pm
ericvv
My Kaymar remains excellent, virtually as new. I only have one small paint flake gone at the side of the main mounting plate. That will be taken care of this spring. But otherwise, no complaints, it is on the truck for I think 4 years now.
Post #299166 15th Jan 2014 8:38pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Don't bother with hammerite, it comes off nearly as quickly as you can paint it on!
Post #299342 16th Jan 2014 2:19pm
