![]() | Home > Technical > Crossmember mounting |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Something I only noticed today is the extra 4 bolts on a 90 crossmember that a 110 doesn't have.
I assume it's just the way the body is mounted, but what is it? You can see the extra 4 bolts on the outside edges of the crossmember. I realise this is common knowledge, but as I've never owned a 90, I didn't realise they existed. ![]() 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
i **think** someone on here mentioned seatbelt mounting brackets or something of that sort? sure i saw these mentioned in topics about fitting rear seats to a 90HT, but i stand corrected if someone knows better.
they're not present on a 90 HT (at least they weren't on my '58 plate 90 county hard top 2.4) so that indicates seats to me? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2667 ![]() ![]() |
its what the seat belts bolt to, its a bracket thing
My 110 has them
That makes sense than.
I guess a 110 7 seater has them. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Yep, 110's with the factory fit bench seats have them fitted, and aren't they a pain in the arris when you want to fit bumperettes
Correct. Here you see them on my 7 seater, they were painted black together with the rear crossmember. ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
Eric, did you hammerite your kaymar carrier? Mine's rusting like a good'un. Needs to be blasted, Galv'd and coated with something...Not quite decided what!
My Kaymar remains excellent, virtually as new. I only have one small paint flake gone at the side of the main mounting plate. That will be taken care of this spring. But otherwise, no complaints, it is on the truck for I think 4 years now.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Don't bother with hammerite, it comes off nearly as quickly as you can paint it on!
