Home > My Defender > g-macks 110 300 tdi thread
Page 12 of 25 <123 ... 111213 ... 232425>
g-mack
fitted crankcase breather today. so now wading breathers are complete
 My 109 thread
my youtube channel
Post #342564 3rd Jul 2014 5:48pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
You know an X-brake makes sense Razz
Post #342584 3rd Jul 2014 7:31pm
g-mack
if i havent cured the banging from it this time an x- brake is going on!! Thumbs Up My 109 thread
my youtube channel
Post #342621 3rd Jul 2014 9:42pm
g-mack
well after full handbrake strip down, im still getting a banging from it. it cured it for about 30 mins but its back again.
so as ive got a whole drum unit off my old td5 disco that never knocked, im gonna see if it fits. hopefully that should sort it.
im edging closer to an x brake at this rate. My 109 thread
my youtube channel
Post #343444 7th Jul 2014 1:22pm
familymad
I would really prefer you to fit an x brake for when I buy it Whistle Rolling with laughter . I love this machine. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #343450 7th Jul 2014 1:40pm
g-mack
hands off matey shes mine!!! all mine!!! Rolling with laughter Rolling with laughter My 109 thread
my youtube channel
Post #343459 7th Jul 2014 2:14pm
g-mack
lost servo assistance completely whilst pulling up to a t junction tonight. not pleasant! Shocked had a quick look under bonnet, V pump doesn't sound any different, and couldn't hear sucking air when i switched it off. i suspect the return valve may be shot! got a spare one if it is but just cannot be arsed to do it tonight!!! My 109 thread
my youtube channel
Post #346769 21st Jul 2014 7:04pm
g-mack
In process of replacing head gasket, while its off i have drained and flushed all coolant from engine rad and heater. removed all breather pipe work, intercooler, oil cyclone thingy! and given everything a thorough clean.
replaced a broken air filter mount
tested break vacuum hose, thats ok!
ordered replacement vac pump, easier to change whilst everything is apart!
im just waiting for the vac pump then i can start putting it all back together!!
also fitted new air and oil filter.
hopefully this will cure very loud exhaust like droning and coolant use!!
here are a few pics along the way
head off
gasket blowing slightly around C4
deck and head cleaned
intercooler out for clean
other bits getting a clean up
 My 109 thread
my youtube channel
Post #348051 28th Jul 2014 4:02pm
g-mack
STILL waiting for new vac pump to arrive !
Easier fitting with air box bracket off, but that is held on by head bolts!!
So done as much as I could without torquing head!
shiny head gasket
sequence marked on bolts for ease
rocker cover is obviously not fitted! just resting there My 109 thread
my youtube channel
Post #348259 29th Jul 2014 6:17pm
g-mack
This came today
got it fitted this morning so I could crack on with cylinder head My 109 thread
my youtube channel
Post #348403 30th Jul 2014 5:10pm
g-mack
Still not running!!!!
Torqued head up successfully, attached exhaust manifold - lost a nut!!
Re attached all water pipes , lost one jubilee clip!!
Attached all leak offs injectors and glow plugs - dropped teeny glow plug nut never to be found again!!
Lost bolt for rear lifting hoop!!
All air and turbo pipes back on
Come to fit rocker assembly and one collet missing!!! Argh!!!!!!!!!!
Also lost rubber washer for rocker cover!
 My 109 thread
my youtube channel
Post #348405 30th Jul 2014 5:20pm
g-mack
so just need to order a few bits, get the rocker shaft back in set tappets fill with new oil and antifreeze., refit inlet manifold and fingers crossed i will be back on the road!!! My 109 thread
my youtube channel
Post #348406 30th Jul 2014 5:22pm
shaggydog
At least you have a shopping list Thumbs Up
Post #348418 30th Jul 2014 6:47pm
g-mack
well its all back together and running again! wont really know how succeful the gasket swap was til ive stuck some miles on it!.
new vac pump sorted brakes so that's a positive, BUT i still have the droning noise at higher revs!! Crying or Very sad
Im hoping I may have the answer to that!
since putting it all back together the airbox is rattling on tick over! so after playing around with it briefly i notice the whole noise under the bonnet goes a lot quieter when i hold the airbox at different angles!
So I'm hoping there is a leak in the air intake side that could be causing this awful droning!! My 109 thread
my youtube channel
Post #349933 6th Aug 2014 2:59pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
If the hand brake is knocking as you slow down to a stop, slacken off the adjuster a bit, it means the shoes are grabbing the drum and causing back lash in the transfer box.
Hopefully should cure it. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #350070 7th Aug 2014 6:11am
