Home > Td5 > Hazard switch, headlight adjustment switch illumination
Waldo
So,
The back light for my hazards switch no longer illuminates when I have my headlights on.
Neither does it work when the hazards are switched on whether the headlights are on or off (but the indicators do still flash outside).
Now am I right in thinking that this will simply due to a blown bulb that will need replacing? (I think I read this somewhere) or is it a new switch.
Also my headlight height adjustment switch isn't illuminated, however I can't remember if it should be.
Another blown bulb or should it be forever in darkness and has always been so?
I'm running a 03, TD5 90 XS CSW
Regards
Will Defender 90 XS TD5 (03 Reg)
Post #297841 11th Jan 2014 7:13pm
Laurie
The headlight adjustment switch is not illuminated.
Post #297845 11th Jan 2014 7:17pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
It's definitely a bulb in the hazard light switch and I would say its most likely blown. I had to replace one in mine for the same reason. As for the headlamp levelling switch I have no idea. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #297848 11th Jan 2014 7:21pm
Waldo
Thanks guys,
Don't suppose anyone has a link to an appropriate bulb???
Also, seems silly they don't illuminate the headlight adjustment switch as the only time you adjust them is when it's dark.... so can't see the switch haha Defender 90 XS TD5 (03 Reg)
Post #297858 11th Jan 2014 7:31pm
ericvv
Post #297862 11th Jan 2014 7:45pm
Waldo
I did find that thread.. But as you said it's for the puma hence the question
Post #297865 11th Jan 2014 7:49pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
im pretty sure my headlamp leveling switch is illuminated, i know for sure my air con ones are as i can remember checking them and there the same style of switch
Will 2005 90 XS
1954 86'' Series 1 tilt
Post #297885 11th Jan 2014 8:17pm
Will
It's the same switch, Will. The thread that Eric has linked to does answer your question. Darren
Post #297903 11th Jan 2014 8:50pm
JWL
I can confirm that the headlight levelling switch is lit up with the rest of them.
Post #297914 11th Jan 2014 9:15pm
Waldo
Okey cokey thanks a lot everyone
Post #297929 11th Jan 2014 9:49pm
