Home > Td5 > Hazard switch, headlight adjustment switch illumination |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
The headlight adjustment switch is not illuminated.
11th Jan 2014 7:17pm |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
It's definitely a bulb in the hazard light switch and I would say its most likely blown. I had to replace one in mine for the same reason. As for the headlamp levelling switch I have no idea. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
11th Jan 2014 7:21pm |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Thanks guys,
Don't suppose anyone has a link to an appropriate bulb??? Also, seems silly they don't illuminate the headlight adjustment switch as the only time you adjust them is when it's dark.... so can't see the switch haha Defender 90 XS TD5 (03 Reg) |
11th Jan 2014 7:31pm |
A simple search would have given you the following, albeit for a Puma, but probably that will be the same bulbs as yours:
http://www.defender2.net/forum/topic12482....witch+bulb Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
11th Jan 2014 7:45pm |
I did find that thread.. But as you said it's for the puma hence the question
Will Defender 90 XS TD5 (03 Reg) |
11th Jan 2014 7:49pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 541 |
im pretty sure my headlamp leveling switch is illuminated, i know for sure my air con ones are as i can remember checking them and there the same style of switch
Will 2005 90 XS 1954 86'' Series 1 tilt |
11th Jan 2014 8:17pm |
It's the same switch, Will. The thread that Eric has linked to does answer your question. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
11th Jan 2014 8:50pm |
I can confirm that the headlight levelling switch is lit up with the rest of them.
11th Jan 2014 9:15pm |
Okey cokey thanks a lot everyone
11th Jan 2014 9:49pm |
