Home > Technical > Is this 'sensor' supposed to be there?
What puddle?
Can someone tell me if this is supposed to just hang there? My 90 is a V8 50th Anniversary, and this 'sensor' is hanging just below the fuel filler pipe - which is at the rear on these 90s. Thanks.
 Now left.
Post #297820 11th Jan 2014 5:51pm
238kirk
United Kingdom 2003 Defender 90 Td5 SW Belize Green
That's the one way valve for the tank breather Thumbs Up
It's should be clipped up out of the way and pointing down
Post #297822 11th Jan 2014 5:53pm
Looks like the end has snapped off too, as it should be curled around, like the end of the axle breather pipes.
Post #298013 12th Jan 2014 9:18am
What puddle?
Many thanks to both of you - I will get the people who serviced it a few weeks ago to have a look. Cheers. Now left.
Post #298042 12th Jan 2014 11:37am
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
I`ve just had a look at my friends anniversary and it has the exact same pipe hanging down the same way. Its also the same at the end as it is cut off at 45 degrees so perhaps its meant to be like that? Couldn`t see where it was meant to be clipped to but will secure it with a cable tie until I can get a look at another one for reference. Smile
Post #298043 12th Jan 2014 11:54am
All the ones i've bought new to fit to my projects have a hoop on the end.
Post #298055 12th Jan 2014 1:12pm
