![]() | Home > Technical > Is this 'sensor' supposed to be there? |
238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233 ![]() ![]() ![]() |
That's the one way valve for the tank breather
![]() It's should be clipped up out of the way and pointing down |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6216 ![]() ![]() ![]() |
Looks like the end has snapped off too, as it should be curled around, like the end of the axle breather pipes.
What puddle? Member Since: 25 Oct 2013 Location: Reading Posts: 952 ![]() ![]() |
Many thanks to both of you - I will get the people who serviced it a few weeks ago to have a look. Cheers. Now left.
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
I`ve just had a look at my friends anniversary and it has the exact same pipe hanging down the same way. Its also the same at the end as it is cut off at 45 degrees so perhaps its meant to be like that? Couldn`t see where it was meant to be clipped to but will secure it with a cable tie until I can get a look at another one for reference.
All the ones i've bought new to fit to my projects have a hoop on the end.
