Home > For Sale & Wanted > [Wanted] Td5 DRIVERS DOOR
Razler
United Kingdom 2002 Defender 90 Td5 HT Zambezi Silver
Drivers door required in good straight rust/corrosion free state preferably silver but can have painted
Pm with details
Post #297321 9th Jan 2014 9:53pm
jimbob7
Alloy or steel door,they changed them bout 05-06.Not got either BTW,just sayin. Pov.spec,ftw. 2006, 110,TD5.
Post #297343 9th Jan 2014 10:47pm
Razler
Ah, cheers for info.. Mines is an 02, am I right in thinking its steel frame alloy skin? What would be the better door to have? Also I notice on the tdci defenders the tops of the door frames are press instead of welded, what's the advantages if any?
Post #297358 9th Jan 2014 11:23pm
jimbob7
Yeah, yours is steel frame alloy skin, I believe the later all steel doors are the best they dont seem to crack (probably coz it's a pressed frame) or rust as quick. Pov.spec,ftw. 2006, 110,TD5.
Post #297431 10th Jan 2014 9:38am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Anyone know which bits will transfer from the older steel frame/ali skin to the newer doors?
Will the winders, handles, seals, glass, door card fit or are they different?
Post #297434 10th Jan 2014 9:47am
thepetrolhead
United Kingdom 2003 Defender 90 Td5 CSW Oslo Blue
Yes they are different....
Door cards are different on the later doors as the doors are all steel. The profile on the actual door card is slightly different. Please read the comments in the following link:
http://www.lrisolutions.co.uk/index.php/ge...i-td5.html
Post #297613 10th Jan 2014 8:16pm
