Home > Maintenance & Modifications > intercooler install - none air con front but the car has it?
Likeomg
started to install my intercooler and came a cropper..
does anyone have a good guide? i can't figure out how to take the bonnet latch brace out? do i need to remove a wing?
Post #296935 8th Jan 2014 5:34pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
No need to remove the wing! The brace is held in place onto the chassis bracket by a nut and bolt in each bottom corner (13mm Spanners) and 2 long bolts at the top that screw upwards from underneath into the bonnet catch (10mm socket), removing them lets you release the 2 cross braces. If you need to remove the landing panel that is held in place by 4 bolts that screw into captive fittings in the wing. (13mm Socket) Hope this helps!
Post #296942 8th Jan 2014 5:41pm
Likeomg
makes sense, will go out and give it a blast, cheers.
Post #296943 8th Jan 2014 5:42pm
dondiddy
You might have to remove the electric fan to give you better access to the bolts at the latch. Its a bit like playing Twister when your trying to look up under the landing panel to see where the bolts are! Great fun! Laughing
Post #296949 8th Jan 2014 5:45pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
use a stud extractor for the 4 bolts...saves damage to inner wings trying to prise off the bracket.. Putting Dreams on Drives at JLR Solihull..
Post #296961 8th Jan 2014 6:10pm
Likeomg
Looks like the inter cooler won't fit my car unfortunately that's a bit of a bummer as the cars now in bits...
Not wide enough to fit around...
Post #296975 8th Jan 2014 6:59pm
dondiddy
Was the intercooler specifically for a Puma Defender? What make was it?
Post #296979 8th Jan 2014 7:19pm
Likeomg
Yeah defender specific from one of the site sponsors, I'll wait and see what they say but for the price of it £500 ish I'm
Not too impressed so far
Post #296984 8th Jan 2014 7:24pm
munch90
that's not factory fit aircon .. that's why you having trouble fitting intercooler
Post #297002 8th Jan 2014 8:17pm
geobloke
Re: intercooler install - none air con front but the car has
Ah that is neat. I also have a none-aircon front but it has it... although the aircon condenser rad is in front of the intercooler...
Which intercooler did you buy?
Post #297030 8th Jan 2014 9:39pm
Likeomg
the black alive ultimate one, i guess most performance intercoolers won't fit my car... will speak to gary and see if i can go down his soon and see what he thinks
Post #297032 8th Jan 2014 9:51pm
munch90
what if you fitted a proper defender aircon condenser in front of the intercooler ( you may have to fit aircon grille panel ). also may have to fit aircon hoses and pipes to go with it
Post #297035 8th Jan 2014 10:03pm
Likeomg
i actually have the air con grill (sticky out thing) need a few extra parts to put it on, and ill go down and have a word with alive this weekend hopefully
Post #297037 8th Jan 2014 10:07pm
geobloke
This is what I have and it is a tight squeeze but you do not need the aircon grille. Have been tempted to put the aircon grille on though Rolling Eyes
Post #297062 8th Jan 2014 10:41pm
K9F
I fitted the exact same one to my 90XS and it took me a considerable amount of time. A little 'fettling' was required but worth it in the end. On my 90 I did not have the angled strut braces depicted on yours which also suggests your aircon may be aftermarket perhaps? I did manage to fit it without disturbing the air con condensor but it was a tight fit. You need to remove the studs at one end of your bonnet brace to remove it completely. I mislaid the cable retaining insert in the process which just drops out when the cable is extracted. Never did find it but change out of £2 for a new one.
K9F wrote:
Being a great advocator and believer in 'You get what you pay for' I decided to wait. Serck were available but I resisted the temptation. Made a subsequent call earlier in the week to see if and when they would be available. I was also after a set of silicone hoses as well.
Phonecall made I was informed first batch were in and that (after a little persuasion) a set of stainless steel interconnecting hard-pipes with silicone attachments were possibly to be had too.
12 hours to strip and fit, claret all over the engine bay due to hands being cut to shreds, but am I happy? Hell yes! Great advice and photographs for the fitment from a fellow forum member. You know who you are and yet another BIG THANK YOU to the member concerned.
Bow down Thumbs Up
Photographs speak a thousand words so here's a few against a stock intercooler as comparison. Starting of course with the arrival of a very well packaged parcel.....Worth the wait as excellently engineered and finished. The service from Gary at Alive was top notch too, with update when package was being sent and when arrival could be expected.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #297064 8th Jan 2014 10:45pm
