![]() | Home > Maintenance & Modifications > intercooler install - none air con front but the car has it? |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
started to install my intercooler and came a cropper..
does anyone have a good guide? i can't figure out how to take the bonnet latch brace out? do i need to remove a wing? ![]() Click image to enlarge |
makes sense, will go out and give it a blast, cheers.
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
You might have to remove the electric fan to give you better access to the bolts at the latch. Its a bit like playing Twister when your trying to look up under the landing panel to see where the bolts are! Great fun!
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
use a stud extractor for the 4 bolts...saves damage to inner wings trying to prise off the bracket.. Putting Dreams on Drives at JLR Solihull..
Looks like the inter cooler won't fit my car unfortunately that's a bit of a bummer as the cars now in bits...
Not wide enough to fit around... |
Was the intercooler specifically for a Puma Defender? What make was it?
Yeah defender specific from one of the site sponsors, I'll wait and see what they say but for the price of it £500 ish I'm
Not too impressed so far |
that's not factory fit aircon .. that's why you having trouble fitting intercooler
Ah that is neat. I also have a none-aircon front but it has it... although the aircon condenser rad is in front of the intercooler... Which intercooler did you buy? |
the black alive ultimate one, i guess most performance intercoolers won't fit my car... will speak to gary and see if i can go down his soon and see what he thinks
what if you fitted a proper defender aircon condenser in front of the intercooler ( you may have to fit aircon grille panel ). also may have to fit aircon hoses and pipes to go with it
i actually have the air con grill (sticky out thing) need a few extra parts to put it on, and ill go down and have a word with alive this weekend hopefully
This is what I have and it is a tight squeeze but you do not need the aircon grille. Have been tempted to put the aircon grille on though ![]() |
I fitted the exact same one to my 90XS and it took me a considerable amount of time. A little 'fettling' was required but worth it in the end. On my 90 I did not have the angled strut braces depicted on yours which also suggests your aircon may be aftermarket perhaps? I did manage to fit it without disturbing the air con condensor but it was a tight fit. You need to remove the studs at one end of your bonnet brace to remove it completely. I mislaid the cable retaining insert in the process which just drops out when the cable is extracted. Never did find it but change out of £2 for a new one.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
