Home > Td5 > which oil?
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
which oil?
I am considering servicing my defender rather than use a dealer / garage. However, doing some research on what oils, particularly engine oil, it is a bit confusing as some people are advocating 5w/30 semi synthetic whilst others say fully synthetic...which is it?
BTW I will use genuine filters and will service every year or 12k.
any advice welcome.
Post #296184 5th Jan 2014 11:11pm
mk1collector
Don't know which oil but Landrover recommend servicing every 6k miles
Post #296200 5th Jan 2014 11:48pm
Tommo
Shocked 6k!
the service portfolio I got with the defender says 12k for the td5 or 12 months.
I guess if I could afford it then every 6k but it will not have hard use (not all the time anyway Wink ) so 12k it is.
Post #296201 5th Jan 2014 11:57pm
jimbob7
Castrol Magnatec 5w30 A1 spec, bout £20 for 4 litre in Cost-co,Tesco have it on offer for similar price sometimes. Pov.spec,ftw. 2006, 110,TD5.
Post #296210 6th Jan 2014 1:16am
Tommo
the Castrol oil does seem a good bet and its fully synthetic!
Post #296413 6th Jan 2014 8:20pm
excossack
I purchases 20l of Fuchs Titan XTR 5/30 from Opie oils. Plenty for a couple of oil changes and I also use in on the wifes Focus Smile 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #296444 6th Jan 2014 9:48pm
Podrob
Any A1, B1 semi or fully synthetic 5W30 or 5W40. If changing at 6000 miles use semi, if changing at 12,000 miles fully synthetic is better.
Post #297089 8th Jan 2014 11:36pm
Porny
Site Sponsor
Also - change both oil filters... I never see the point in just changing one!
Any good quality 5w30 oil will suffice - fully synthetic is the better choice.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #297092 8th Jan 2014 11:41pm
Tommo
Thanks all for advice.
Going to go for fully synthetic oil (probably Castrol Magnetic) and buy genuine service kit from somewhere such as Duckhams.
Porny- the service kit does contain both filters Very Happy
Post #297471 10th Jan 2014 11:52am
Porny
Site Sponsor
Tommo... I keep all filters in stock Wink
OEM so man-hummel and mahle.. same as genuine, but in a different box.
Ian IRB
Post #297474 10th Jan 2014 12:04pm
Marky Boy
Hi all,
Quick question - can you mix synthetic and semi synthetic oils. My TD5 was serviced by a dealer and I would like to buy some for top ups. Therefore does it matter which one I buy ?
The reason behind this is that I seem to remember with motorbikes a few years ago it was considered a no no to mix synthetics with minerals etc.
Post #300846 21st Jan 2014 2:06pm
Tommo
To be honest I don't know but would guess keep to one or the other and not mix Confused
Post #300990 21st Jan 2014 8:25pm
RockJaw
United States 2013 Defender 110 Puma 2.2 SW Santorini Black
Tommo, if it is any use to you, we have been using Defenders and Cruisers sine 1972 in both military and mining applications and i can tell you that the best results we always had has been with Amsoil - hands down the best results of every oil we have ever used.
For Defenders use the OEM LR filters and Amsoil 5W30 Series 3000 Heavy Duty Diesel Engine oil - for cold climates use 0W20.
And no, you do not want to mix synthetic with natural oil - bad idea. ****CENSORED****
Post #304013 1st Feb 2014 10:48am
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Unipart do a 20ltr 5w30 fully synthetic A5/B5 for about £48 plus VAT. (Fuch oil as far as I know).
I've used for circa 5 years on D3 and Defender.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #304103 1st Feb 2014 3:25pm
