![]() | Home > Td5 > which oil? |
Don't know which oil but Landrover recommend servicing every 6k miles
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
![]() the service portfolio I got with the defender says 12k for the td5 or 12 months. I guess if I could afford it then every 6k but it will not have hard use (not all the time anyway ![]() |
Castrol Magnatec 5w30 A1 spec, bout £20 for 4 litre in Cost-co,Tesco have it on offer for similar price sometimes. Pov.spec,ftw. 2006, 110,TD5.
the Castrol oil does seem a good bet and its fully synthetic!
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018 ![]() ![]() ![]() |
I purchases 20l of Fuchs Titan XTR 5/30 from Opie oils. Plenty for a couple of oil changes and I also use in on the wifes Focus
![]() Regards John M0VAZ Econet Station 48 no clock |
Podrob Member Since: 20 May 2012 Location: Co Derry, N Ireland Posts: 31 ![]() ![]() ![]() |
Any A1, B1 semi or fully synthetic 5W30 or 5W40. If changing at 6000 miles use semi, if changing at 12,000 miles fully synthetic is better.
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Also - change both oil filters... I never see the point in just changing one!
Any good quality 5w30 oil will suffice - fully synthetic is the better choice. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Thanks all for advice.
Going to go for fully synthetic oil (probably Castrol Magnetic) and buy genuine service kit from somewhere such as Duckhams. Porny- the service kit does contain both filters ![]() |
Tommo... I keep all filters in stock
![]() OEM so man-hummel and mahle.. same as genuine, but in a different box. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Marky Boy Member Since: 25 Oct 2013 Location: Maidenhead Posts: 96 ![]() ![]() |
Hi all,
Quick question - can you mix synthetic and semi synthetic oils. My TD5 was serviced by a dealer and I would like to buy some for top ups. Therefore does it matter which one I buy ? The reason behind this is that I seem to remember with motorbikes a few years ago it was considered a no no to mix synthetics with minerals etc. Cheers |
To be honest I don't know but would guess keep to one or the other and not mix
RockJaw Member Since: 15 Oct 2013 Location: United States Posts: 317 ![]() ![]() ![]() |
Tommo, if it is any use to you, we have been using Defenders and Cruisers sine 1972 in both military and mining applications and i can tell you that the best results we always had has been with Amsoil - hands down the best results of every oil we have ever used.
For Defenders use the OEM LR filters and Amsoil 5W30 Series 3000 Heavy Duty Diesel Engine oil - for cold climates use 0W20. And no, you do not want to mix synthetic with natural oil - bad idea. ****CENSORED**** |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Unipart do a 20ltr 5w30 fully synthetic A5/B5 for about £48 plus VAT. (Fuch oil as far as I know).
I've used for circa 5 years on D3 and Defender. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
