Home > Td5 > TD5 Running Lumpy |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Hi All,
quick question. drove to the shop today and engine running fine and smooth, come out the shop and engine is running lumpy mis fire like? it pulls away but when it tries to get higher revs it feels like it splutters and has no go in it. I have checked the red ecu plug and dry as a bone (had new loom last feb and AFM same time. I have checked and it has oil can't see/feel any delamination on the intercooler pipes not over heating no excessive smoke no noticeable leaks form any where on engine I'm now at a loss?? various threads I have read say could be turbo actuator? would this cause lumpy running? if not what else could it be?? many thanks in advance 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
29th Dec 2013 8:15pm |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
Or if not sensor, then may be fuel filter, the rac man should tell you what's wrong and cheaper than taking it to land rover!
29th Dec 2013 8:45pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Disconnect the MAF sensor and drive it,if misfire goes then replace MAF.
Changed mine recently due to intermittent power loss bought it From BAS (site sponser) quality part and quick delivery. 2005 Td5 90 XS Steve |
29th Dec 2013 9:22pm |
I've already disconnected maf and no change plan on cleaning out fuel filter on weds.
failing that i'll take it to work on sat and get them to check with diag machine 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
29th Dec 2013 9:26pm |
Could be injector seals try running through the purge procedure before starting see if that improves it. 2005 Td5 90 XS
Steve |
29th Dec 2013 9:45pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
It's worth checking the free movement of the turbo wastegate actuator (as OP mentioned). I've not suffered from this so have no personal experience but I seem to recall the symptoms are more likened a speed limiter ... might be wrong on that.
Other than the already mentioned things, MAF/Fuel Filter/Injectors, the only other thing that I can suggest may be worth doing is removing the MAP sensor (on inlet manifold) and giving that a clean up. They do get pretty gunked up, particularly if you still running with the EGR in situ. Jon - 110 td5 [sold]. Currently Defenderless. |
29th Dec 2013 11:31pm |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 720 |
Does it smoke? Mine did with same symptoms, new maf, etc etc, even checked wiring over transfer box in pouring rain (wires chafe, common misfire prob). Then mech pal disconnected egr valve( pulled off vacuum pipes, 20 secs work!) runs a dream...... Egr blanking kit ordered for mine!!
Hth Alex |
30th Dec 2013 1:11am |
jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231 |
Just had this problem and it was No1 injector........ Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
30th Dec 2013 2:53pm |
well this afternoon I have replaced fuel filter and sender on bottom and it ran and started to clear after 20 seconds or so and then stopped and wont re start diagnosis the in tank pump is fubar no noise what so ever!!! 2008 110 2.4 XS Utility (Hagrid)
31st Dec 2013 5:28pm |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 |
ign on, quick stabs 5 on accelerator to start the airing process, it will tell you quickly if the pump runs or not.
If the MAF is fubar it will still run, but fuel consumption will be hi. Have you checked the fuel pressure regulator, those have a habit of leaking too "Rafiki" 2007 110 STW - Rolling rebuild. |
31st Dec 2013 9:02pm |
Already replaced maf and tried to bleed no life from pump going to check relays before replacing pump though 2008 110 2.4 XS Utility (Hagrid)
31st Dec 2013 10:56pm |
just a quick update replaced fuel pump today and now purring like a kitten again thanks for all your inputs
Paul 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
12th Jan 2014 5:01pm |
