![]() | Home > Td5 > TD5 Running Lumpy |
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
Hi All,
quick question. drove to the shop today and engine running fine and smooth, come out the shop and engine is running lumpy mis fire like? it pulls away but when it tries to get higher revs it feels like it splutters and has no go in it. I have checked the red ecu plug and dry as a bone (had new loom last feb and AFM same time. I have checked and it has oil can't see/feel any delamination on the intercooler pipes not over heating no excessive smoke no noticeable leaks form any where on engine I'm now at a loss?? various threads I have read say could be turbo actuator? would this cause lumpy running? if not what else could it be?? many thanks in advance 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
| Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861
Or if not sensor, then may be fuel filter, the rac man should tell you what's wrong and cheaper than taking it to land rover!
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Disconnect the MAF sensor and drive it,if misfire goes then replace MAF.
Changed mine recently due to intermittent power loss bought it From BAS (site sponser) quality part and quick delivery. 2005 Td5 90 XS Steve |
I've already disconnected maf and no change plan on cleaning out fuel filter on weds.
failing that i'll take it to work on sat and get them to check with diag machine 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Could be injector seals try running through the purge procedure before starting see if that improves it. 2005 Td5 90 XS
Steve |
| party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311
It's worth checking the free movement of the turbo wastegate actuator (as OP mentioned). I've not suffered from this so have no personal experience but I seem to recall the symptoms are more likened a speed limiter ... might be wrong on that.
Other than the already mentioned things, MAF/Fuel Filter/Injectors, the only other thing that I can suggest may be worth doing is removing the MAP sensor (on inlet manifold) and giving that a clean up. They do get pretty gunked up, particularly if you still running with the EGR in situ. Jon - 110 td5 [sold]. Currently Defenderless. |
| alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729
Does it smoke? Mine did with same symptoms, new maf, etc etc, even checked wiring over transfer box in pouring rain (wires chafe, common misfire prob). Then mech pal disconnected egr valve( pulled off vacuum pipes, 20 secs work!) runs a dream...... Egr blanking kit ordered for mine!!
Hth Alex |
| jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231
Just had this problem and it was No1 injector........ Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
well this afternoon I have replaced fuel filter and sender on bottom and it ran and started to clear after 20 seconds or so and then stopped and wont re start diagnosis the in tank pump is fubar no noise what so ever!!!
| Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 251
ign on, quick stabs 5 on accelerator to start the airing process, it will tell you quickly if the pump runs or not.
If the MAF is fubar it will still run, but fuel consumption will be hi. Have you checked the fuel pressure regulator, those have a habit of leaking too "Rafiki" 2007 110 STW - Rolling rebuild. |
Already replaced maf and tried to bleed no life from pump going to check relays before replacing pump though 2008 110 2.4 XS Utility (Hagrid)
just a quick update replaced fuel pump today and now purring like a kitten again thanks for all your inputs
Paul 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
