Home > Maintenance & Modifications > corner protection in combination with wheel carrier
p_jeeeee
Belgium 2007 Defender 90 Puma 2.4 SV 90 Caprice
Has anybody some experience with the combination of a mantec Wheel carrier and terrafirma corner protection? I can�t mount it because of the bracket of my wheelcarrier.
I also have to modify my mud flaps to mount my bumperettes, anybody tips and tricks?
Any help is welcome, photos say more than 1000 words!
Post #293384 27th Dec 2013 11:59am
I had the same issue a few years ago on my td5, after thinking about it I shortened the bumperette, it did involve some welding but did not take long.
Post #293385 27th Dec 2013 12:09pm
Ianl
First four do a version designed to fit with the wheel carrier, the driver side one is shorter and bolts on to the next set of holes along the crosmember
Post #293388 27th Dec 2013 12:57pm
p_jeeeee
do you have any pictures?
Post #293391 27th Dec 2013 1:16pm
hxk494
I have the first for ones on mine with a Mantec carrier. I can get pics tomorrow one the rain and gales have hopefully passed. Cheers, Martin 1996 300Tdi Defender 110
Post #293522 27th Dec 2013 11:29pm
p_jeeeee
would be great!!!!
Thumbs Up
Post #293524 27th Dec 2013 11:32pm
Litch
This is an old WH carrier combined with a set of bumperettes from Goole Surplus, no issues fitting and also room get a full set of NAS lights in which many set-ups will not allow.
[/URL][/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ONE LIFE, GET IT!
Post #293666 28th Dec 2013 5:00pm
K9F
Not a Mantec but I too had problems fitting the bumperette after my swingaway was fitted. I just measured up, ground off the old 90 degree brackets and welded new ones on.
Measured up.
New brackets fitted replacing original 90 degree brackets.
Fitted. Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #293675 28th Dec 2013 5:29pm
hxk494
Mantec carrier with first four corner protector
Post #293873 29th Dec 2013 12:41pm
hxk494
Post #293874 29th Dec 2013 12:41pm
Jim_Bean
Is there a wheel carrier that will sit happily with the Terrafirma corner bumperettes on a 110?
Been offered a set bumperettes but I would really like a wheel carrier too Confused
Post #333888 27th May 2014 11:49am
K9F
The OP asked the same question re a Mantec swingaway. BPman responded that some adjustment had to be made. Unfortunately a lot of swingaways utilise the same mounting holes as the bumperettes. 'Choose carefully and adapt' is the key here I think. There are some pictures back in this thread that the combination does work.
A few 'pointers'.......
leeds wrote:
Safari have done a modified rear bumperettes which works with their wheel carrier. Brendan
http://www.defender2.net/forum/topic16360....umperettes
http://www.defender2.net/forum/topic12229....umperettes If you go through life with your head in the sand....all people will see is an ar5e!!
Post #333890 27th May 2014 12:13pm
Jim_Bean
Thanks for the pointers. It looks like there are combinations that work.
I was looking to see if there was one specifically for the Terrafirma bumperettes as those are the ones i've been offered. If there isn't a carrier compatible with the Terrafirma ones i'll look into the other ones you've pointed out.
Thanks for the tips!
Post #333893 27th May 2014 12:27pm
K9F
Bumperettes are relatively cheap, swingaways aren't. Try to make the bumperettes fit the swingaway, not the other way round. Life will be less complicated.
Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #333923 27th May 2014 3:39pm
Jim_Bean
Agreed. Very Happy
Just thought it worth seeing if a carrier existed that would sit with the Terrafirma bumperettes without any need for modification.
Soo much to do and so little time i guess!
Post #333934 27th May 2014 4:24pm
