![]() | Home > Maintenance & Modifications > corner protection in combination with wheel carrier |
I had the same issue a few years ago on my td5, after thinking about it I shortened the bumperette, it did involve some welding but did not take long.
Ianl Member Since: 29 Dec 2012 Location: Guildford Posts: 5 ![]() |
First four do a version designed to fit with the wheel carrier, the driver side one is shorter and bolts on to the next set of holes along the crosmember
p_jeeeee Member Since: 08 Jan 2012 Location: Flanders Posts: 75 ![]() ![]() ![]() |
do you have any pictures? |
hxk494 Member Since: 29 Apr 2013 Location: Edinburgh Posts: 244 ![]() ![]() |
I have the first for ones on mine with a Mantec carrier. I can get pics tomorrow one the rain and gales have hopefully passed. Cheers, Martin 1996 300Tdi Defender 110
would be great!!!!
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
This is an old WH carrier combined with a set of bumperettes from Goole Surplus, no issues fitting and also room get a full set of NAS lights in which many set-ups will not allow.
[URL=] ![]() Click image to enlarge[/URL][/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Not a Mantec but I too had problems fitting the bumperette after my swingaway was fitted. I just measured up, ground off the old 90 degree brackets and welded new ones on.
Measured up. ![]() Click image to enlarge New brackets fitted replacing original 90 degree brackets. ![]() Click image to enlarge Fitted. ![]() ![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Mantec carrier with first four corner protector
![]() Click image to enlarge 1996 300Tdi Defender 110 |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 ![]() ![]() ![]() |
Is there a wheel carrier that will sit happily with the Terrafirma corner bumperettes on a 110?
Been offered a set bumperettes but I would really like a wheel carrier too ![]() |
The OP asked the same question re a Mantec swingaway. BPman responded that some adjustment had to be made. Unfortunately a lot of swingaways utilise the same mounting holes as the bumperettes. 'Choose carefully and adapt' is the key here I think. There are some pictures back in this thread that the combination does work.
A few 'pointers'.......
http://www.defender2.net/forum/topic16360....umperettes http://www.defender2.net/forum/topic12229....umperettes If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks for the pointers. It looks like there are combinations that work.
I was looking to see if there was one specifically for the Terrafirma bumperettes as those are the ones i've been offered. If there isn't a carrier compatible with the Terrafirma ones i'll look into the other ones you've pointed out. Thanks for the tips! |
Bumperettes are relatively cheap, swingaways aren't. Try to make the bumperettes fit the swingaway, not the other way round. Life will be less complicated.
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Agreed.
![]() Just thought it worth seeing if a carrier existed that would sit with the Terrafirma bumperettes without any need for modification. Soo much to do and so little time i guess! |
