Home > Puma (Tdci) > Audio system
SVX90
United Arab Emirates
Audio system
Has anyone modified the audio system in the new defender?
That sound quality isnt that great.
What is the best audio system out there that can be fitted in the new defender?
Post #23634 5th Feb 2010 3:31pm
alantd
There's a few threads on this. The most common upgrades are larger speakers and a subwoofer. One that started out as a 2.4 TDCi 110 XS
Post #23687 5th Feb 2010 8:15pm
i have a kenwood dvd system with allstandard speakers n sub ect good enough for me Smile
Post #23763 7th Feb 2010 12:42pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
How loud do people need to play radio 4 for godsakes Shocked Original Member Pie n Pea Club.
110 HCPU Tipper
Post #23764 7th Feb 2010 12:55pm
MK
Std quality is really bad! It is not the radio/cd. I fitted some Pioneer speakers on the front doors and improved quite a lot. Puma 110" SW
Post #23766 7th Feb 2010 1:38pm
Its not how loud (unless your dell boy Whistle ) the standard system has no depth at all
Spent a while and I have it right for me Thumbs Up
Post #23767 7th Feb 2010 2:22pm
willy eckerslike
Dell boy, is he still alive, haven't heard from him for a while. What have you put in audio wise ken, (tongue in cheek re radio 4 honest) I know what you mean about depth. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #23769 7th Feb 2010 2:51pm
CapeLandy
South Africa
as an aside, do any of you get a popping noise through the speakers when the AF searches for a stronger signal - alsmos souds like a loose connection or bad arial earth.
Post #23779 7th Feb 2010 5:23pm
Mr.Boots
Ireland
Im gonna get some good rear speakers in Halfords that will fit in the original space, ill see how that goes but will probably end up with an active amp also.
Also need to upgrade the standard land rover head unit eventually....its not too bad though.
Post #23783 7th Feb 2010 5:47pm
peanutbob
Try listening to the Archers with the aircon on and the fan on level 2 or worse still level 3 , in an effort to stop the car fogging up with 2 wet dogs in the back. Haven't got a clue what's happened this winter. And as for Desert Island discs...well every time its on it features people from both sides of the coin if you get me drift...
Post #23803 7th Feb 2010 10:55pm
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Best Audio System
I replaced the Speakers in my SVX, with Pioneer Two way units (same 4" size).
I also upgraded the headunit to an Alpine iDA-X305 and that with the AUDYSSEY system (Alpine IMPRINT) has given me much better, and balanced, sound quality.
Post #23899 9th Feb 2010 1:16am
draymond
Best Audio System
Post #23900 9th Feb 2010 1:43am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Good choice draymond, my iDA-X305 arrived today Very Happy
I'm looking to have a go at fitting mine on the weekend, the main question that springs to mind is - is there somewhere obvious that everybody has their iPod connector exiting from behind the dash? Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #23961 9th Feb 2010 8:48pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
in the cubby hole where your ignition is is quite a good one, then get a bit of velcro and stick your iPod onto the large vertical piece of plastic to the right of the heater / stereo 110 Tdci Double Cab
Post #23966 9th Feb 2010 10:11pm
discocuzzy
Run the cable under the carpet from the center console up into the cubby box if you have one Thumbs Up You cannot teach stupid people to do clever things
Post #23970 9th Feb 2010 10:28pm
