![]() | Home > Puma (Tdci) > Audio system |
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
There's a few threads on this. The most common upgrades are larger speakers and a subwoofer. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
i have a kenwood dvd system with allstandard speakers n sub ect good enough for me
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
How loud do people need to play radio 4 for godsakes
110 HCPU Tipper |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
Std quality is really bad! It is not the radio/cd. I fitted some Pioneer speakers on the front doors and improved quite a lot. Puma 110" SW
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Its not how loud (unless your dell boy Spent a while and I have it right for me |
Dell boy, is he still alive, haven't heard from him for a while. What have you put in audio wise ken, (tongue in cheek re radio 4 honest) I know what you mean about depth. Original Member Pie n Pea Club.
110 HCPU Tipper |
| CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558
as an aside, do any of you get a popping noise through the speakers when the AF searches for a stronger signal - alsmos souds like a loose connection or bad arial earth.
| Mr.Boots Member Since: 04 Feb 2010 Location: Wicklow Posts: 15
Im gonna get some good rear speakers in Halfords that will fit in the original space, ill see how that goes but will probably end up with an active amp also.
Also need to upgrade the standard land rover head unit eventually....its not too bad though. |
| peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 351
Try listening to the Archers with the aircon on and the fan on level 2 or worse still level 3 , in an effort to stop the car fogging up with 2 wet dogs in the back. Haven't got a clue what's happened this winter. And as for Desert Island discs...well every time its on it features people from both sides of the coin if you get me drift... |
| draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49
I replaced the Speakers in my SVX, with Pioneer Two way units (same 4" size).
I also upgraded the headunit to an Alpine iDA-X305 and that with the AUDYSSEY system (Alpine IMPRINT) has given me much better, and balanced, sound quality. |
| MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682
Good choice draymond, my iDA-X305 arrived today
I'm looking to have a go at fitting mine on the weekend, the main question that springs to mind is - is there somewhere obvious that everybody has their iPod connector exiting from behind the dash? Peter 2008 SWB Truck Cab 1952 80" Soft top |
| ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328
in the cubby hole where your ignition is is quite a good one, then get a bit of velcro and stick your iPod onto the large vertical piece of plastic to the right of the heater / stereo 110 Tdci Double Cab
| discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200
Run the cable under the carpet from the center console up into the cubby box if you have one
| All times are GMT |
