Home > Technical > Front wiper stops as soon as you flick the switch off
gambit
Up until recently the front wiper worked absolutely fine.
Now though, whenever I switch off the wipers, they stop immediately and do not return to bottom of the screen.
This happens at all speeds including the intermittent...
So I guessing it isn't the relay?
Post #292440 22nd Dec 2013 5:39pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
.return switch on the motor Exclamation
Found the part number its - 520160. (Same for puma and TD5)
Cost - £7.22 or £21 genuine
try Technical > Wipers wont return home
Post #292464 22nd Dec 2013 6:42pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
Had the same problem a few months ago. Solved by taking off the fuse cover and wiggling the wiper relay about. Worth a try maybe. One wife - livid
Post #292466 22nd Dec 2013 6:55pm
Most likely the park switch on the motor as stated above. Not too difficult to change on a TDCi. If you search you should find a "how to" I posted about 3 years ago.
Post #292571 22nd Dec 2013 11:34pm
jimsadventure
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Just fitted second one to mine ,, at least the part is a cheap one Wink
Post #292585 23rd Dec 2013 12:19am
gambit
Thanks blackwolf...
A bit of thread following after the search and I found this >> http://www.defender2.net/forum/topic11239.html
I have a TD5
Post #292586 23rd Dec 2013 12:29am
