![]() | Home > Technical > Front wiper stops as soon as you flick the switch off |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
.return switch on the motor
![]() Found the part number its - 520160. (Same for puma and TD5) Cost - £7.22 or £21 genuine try Technical > Wipers wont return home |
IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172 ![]() ![]() ![]() |
Had the same problem a few months ago. Solved by taking off the fuse cover and wiggling the wiper relay about. Worth a try maybe. One wife - livid
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17867 ![]() ![]() ![]() |
Most likely the park switch on the motor as stated above. Not too difficult to change on a TDCi. If you search you should find a "how to" I posted about 3 years ago.
jimsadventure Member Since: 10 Nov 2013 Location: edinburgh Posts: 199 ![]() ![]() ![]() |
Just fitted second one to mine ,, at least the part is a cheap one
gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 ![]() |
Thanks blackwolf...
A bit of thread following after the search and I found this >> http://www.defender2.net/forum/topic11239.html I have a TD5 |
