![]() | Home > Technical > F3 Horn gremlin. |
| randallised Member Since: 30 Apr 2012 Location: Doolin Posts: 18
Hi guys
The 110 (05) sw I have has an intermittent fault, the worse ones to diagnose, it blows F3 fuse under drivers seat. When the horn is pressed. Have replaced switch, horn, wiring from switch to horn. Has anyone else had a similar problem on another forum there is mention of the alarm relay playing up ? guess this is the next port of call. LR main dealer say its not a problem they are aware off, auto electrician thought he fixed it - short in radio loom, after relieving me of my hard earnt. MOT is the problem. Sods law it will stop when being tested. Any help appreciated thanks. |
Thanks will give it a try at the weekend.
